How to flush trim T Trak slot - Router Forums
post #1 of 5 (permalink) Old 11-09-2011, 07:00 AM Thread Starter
TheOakDude's Avatar
First Name: Paul
Default How to flush trim T Trak slot
Hi everyone, Need a little help here.
I am in process of building first router table. I have a 2layer 1inch thick marine ply table top onto which I am going put a 1.5mmthick formica top.
I have no probs trimming the formica in Mitre slot as its 20mm deep, but the t trak slot is only 9mm deep and my flush trim router bit is too long, ie the allen screw which is holding in the bearing is in the way. I could remove the bearing but then will have no guidance, would in effect be a straight cutter.
Please help
TheOakDude is offline
post #2 of 5 (permalink) Old 11-09-2011, 08:17 AM
gav
Country: Croatia
First Name: Gavin
2 things come to mind.
Buy a a special bit for trimming in shallow dados, such as this
Flush Trim Router Bits - Small Pilot for Shallow Dado, Solid Carbide - Southeast Tool SCD210 - Carbide Processors
Or, clamp a straight edge at the required offset from the dado and us a normal straight bit to trim the laminate.
gav is offline
post #3 of 5 (permalink) Old 11-09-2011, 09:18 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Paul, I'm not positive that I am understanding your situation as intended, but if I am; you may be able to do one of the following:
1: adjust how your router motor is sitting in the base;
2: add to the thickness of your router's base plate;
3: a bearing guided bit can also be running along a thicker straightedge than what is limiting you. Be careful to clamp effectively - while never blocking the router's intended travel path. OPG3
OPG3 is offline
post #4 of 5 (permalink) Old 11-09-2011, 09:39 AM
HI
I will 2nd Gav post that bit will do a fine job..
post #5 of 5 (permalink) Old 11-09-2011, 10:36 AM
Please help
I assume since you are using flush trim bits, you have guide strips clamped/sticky taped/glued along the intended groove. If thats the case, just use thicker guide strips.
John Schaben
jschaben is offline
Pattern bit / inverted flush trim bit matt1710 Router Bits - Types and Usage 7 01-24-2011 04:55 AM
Pattern Bit or Flush Trim? Harris Router Bits - Types and Usage 1 06-15-2010 12:50 PM
Flush trim bit not flush RuggerJoe Router Bits - Types and Usage 8 03-19-2008 12:57 PM
Flush trim bits Hamlin Router Bits - Types and Usage 4 12-01-2007 01:51 PM
Where to get a flush trim bit? wanart Router Bits - Types and Usage 4 10-28-2006 08:39 AM
