routing small round tables border - Router Forums
post #1 of 5 (permalink) Old 11-19-2011, 12:33 PM Thread Starter
Country: Colombia
First Name: Enrique
Default routing small round tables border
Thanks for making me a member of the router forum.
I have a table router and new at this hobby.
I have a 3/4 inch x 20 inch Diameter plywood and want to give the border a router touch,how I can work to maintain a perfect finish.
Thanks.
spartafoto is offline
post #2 of 5 (permalink) Old 11-19-2011, 12:49 PM
Enrique, a bearing guided bit will ride against the edge of your plywood and use it as a guide so you get a smooth finish. A better choice would be to glue some solid wood boards together and use your router to cut them into a circle. When you use a bearing guided bit or a template guide to follow a shape it is very important that the material be perfectly smooth. Any errors in your surface will be amplified in the cut. This photo shows a bearing guided round over bit set up for safe use. You will find instructions on building the VacGuard in a video on the forums. There are a couple of photos and a cutting list posted in my gallery.
post #3 of 5 (permalink) Old 11-19-2011, 09:41 PM
G'day Enrique
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 11-19-2011, 11:13 PM
xplorx4's Avatar
First Name: Jerry
Greetings Enrique and welcome to the router forums, we are glad to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 5 (permalink) Old 11-21-2011, 08:31 AM Thread Starter
Country: Colombia
First Name: Enrique
JIGS CAN MAKE ROUTING SAFER!! (lesson learned for a newbie) metzgeri Jigs and Fixtures 44 01-25-2011 11:00 AM
Question on small part routing rweerstra Table-mounted Routing 7 11-05-2010 01:31 PM
Routing small pieces of timber colbra General Routing 11 07-01-2009 06:51 AM
Round over on small pattern bondandracing Jigs and Fixtures 9 05-01-2009 11:34 PM
routing edge on round tom41 Jigs and Fixtures 34 01-06-2009 08:19 PM
