Issue MLCS Box joint cutter - Router Forums
post #1 of 7 (permalink) Old 11-29-2011, 02:40 PM Thread Starter
CR1
Default Issue MLCS Box joint cutter
What would you do ~ ~ ~ ~ ~~ ~
Would you Use epoxy to fill little gaps on the order of 0.005" or try to re set the box joint cutter. There's light showing between the fingers at the factory setting.
Had this cutter a while.
When I got it I realized I needed to do a few things before using it.
Those things are done so today I went to cut some box joints
I have 76 drawers to do so Iím only too happy not to be doing this the old fashioned way.
Took a pass. Looks great~!! Happy Happy Happy. Put the parts together mmmmm snug fit. Oh golly Iím a happy camper.
Held the parts up to a harsh light. !! Itís always the harsh light that shows the flaws ainít it?
Thereís light between most of the fingers.
Thatís not good.
There are two solutions: Epoxy (to fill the gaps), or take it apart and set it up right.
The damn cutter wasnít set up right at the factory.
The fingers are not all .156Ē ( 5/32Ē) Hell not one is.
The slots are not 0.156Ē either. They are between 0.162Ē and 0.160Ē The slots are fixed. Thatís what the cutter makes when it takes a pass. I canít adjust the slot I can only adjust the fingers.
The thing came with a slew of 0.005Ē shims. So the challenge is to get all the fingers to match the slots.
I bet this is the difference between a spendy high end cutter and these Cheapo cutters.
The spendy ones come factory set correctly Ė I am guessing.
Damn Chinese canít do anything right.
What would you do: Epoxy or try to set it up right with the limits of having only 0.005Ē shims?
CR1 is offline
post #2 of 7 (permalink) Old 11-29-2011, 03:06 PM
Uhm, were you planning on putting any glue in the joint?
post #3 of 7 (permalink) Old 11-29-2011, 03:15 PM
Hi
I was thinking the same thing..you do need some room for the glue..
post #4 of 7 (permalink) Old 11-29-2011, 06:25 PM Thread Starter
CR1
There should be no room for glue. At least not in the colloquial sense. The glue should have to muscle it's way in. PVA and white glues want a very intimate contact one almost can't apply enough pressure. They work best at very thin cross sections.
Epoxies can fill in little gaps but not titebond and white glue.
The way I put those kinds of joints together where a tight sliding fit is the order of the day Is I glue both surfaces let the glue settle in for a couple minutes and then put it together. There's always plenty of glue on even the tightest of fits.
Anyway I "fixed" the xxxxxx up factory settings. You really should not be able to see light in the fits.
I added two 0.005" shims to positions #4 and #5
here
and it made it all better.
Last edited by TwoSkies57; 12-03-2011 at 03:55 PM. Reason: no need for that kinda language....
CR1 is offline
post #5 of 7 (permalink) Old 12-03-2011, 05:59 PM
Hi Darrink
Oh wow! The dreaded "F" bomb.
I must say, that is very disappointing to see.
I have been on this forum for several years, and this is
the first time I've seen it used. What a shame. "
Mark has software in place that takes it out the norm,
you will see just the **** but it maybe not seeing it in place.
on this one..
Originally Posted by darrink View Post
Deleted
post #6 of 7 (permalink) Old 12-03-2011, 06:04 PM
TwoSkies57's Avatar
Original post already edited. I'll remove the "quoted" now...
Note sent to OP
Skipper the Penguin
TwoSkies57 is offline
post #7 of 7 (permalink) Old 12-03-2011, 06:48 PM
dutchman 46's Avatar
First Name: Howard
Thanks! This is the one thing that keeps Me nice and tight, here! The message can get through very nicely with decent language> Thank you
John 3:16
dutchman 46 is offline
Box Joint Bit bobj3 Router Bits - Types and Usage 18 05-26-2020 08:22 AM
How To Make a Box with a Box Joint learnexperience General Routing 7 08-07-2011 07:07 AM
Box joint jig update horn man Jigs and Fixtures 9 01-07-2010 10:19 PM
Box Joint Jig from "ShopNotes" Magazine old rebel Jigs and Fixtures 12 03-26-2008 10:21 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 08:52 AM
