Incra Joinery Systems - Router Forums
post #1 of 11 (permalink) Old 12-06-2011, 05:25 PM Thread Starter
mjdorsam's Avatar
First Name: MikeD
Default Incra Joinery Systems
I'm not sure if there is enough interest in starting and Incra-specific thread. I have a love-hate relationship with mine (as part of my table saw/router table combo; and would like to hear other views - I'm considering separating the two, with a standalone router system, and I'm not sold on the Kreg or Jessum.
Thanks,
Mike Dorsam
mjdorsam is offline
post #2 of 11 (permalink) Old 12-06-2011, 05:54 PM
Thanks,
Mike Dorsam
Hi Mike - Welcome to the forum
I guess I'm having trouble finding a question somewhere Can you be a little more specific on what you like and, probably more importantly, what you dislike?
John Schaben
jschaben is offline
post #3 of 11 (permalink) Old 12-06-2011, 06:05 PM
TwoSkies57's Avatar
Hey MikeD, welcome to the community....
I've got an LS17 w/wonderfence sitting on a standalone table. The mechanical feature of the rig I didn't like was/is the right angle fence. I just felt it was too sloppy as you pushed it along the fence. I replaced it with a miter-r-slide and love it...
I've got a problem with reading the scale at times A minor thing I know...wish there was a magnifying lens available. I've thought about getting one of those page size magnifiers and replace the lexan lens that is in there now....This is pretty much why I"ve not put one on my table saw yet..I'll have to lean way over to set it up...not sure how well that would work *L*
Other than that...the whole thing is just great!!
Skipper the Penguin
TwoSkies57 is offline
post #4 of 11 (permalink) Old 12-07-2011, 07:35 AM Thread Starter
mjdorsam's Avatar
First Name: MikeD
John, TwoSkies57:
Thanks for the follow-up - and John, I should have specified both a question and the dark-side of my experience. I find the Wonderfence to be both short and the two sides (of the split fence) to go out of alignment; as the alignment is predicated on securing each half independently to the main fence. Dust collection seems less efficient than that of Kreg's, due to the placement of the exhaust at the end of the fence, rather than at the Bit. For the question part of this, I was wondering if others find these issues, or is it just my not having experience with other tables and fences as a comparison?
Thanks,
mjdorsam is offline
post #5 of 11 (permalink) Old 12-07-2011, 05:16 PM
TwoSkies57's Avatar
Mike.. I'll give ya another couple cents worth if you don't mind...
regarding the fence alignment... It does not take much in the way of sawdust to give ya fits. Anytime I need to make any kind of split fence adjustment, I make sure that everything is nice and clean. For me anyways, this seemed to take care of the problem.
Dust collection I've had pretty good luck with. I pretty much run a 2" PVC collection system. Total travel is about 40 feet with multiple T's and elbows with six ports and I still have excellent collection. I tie my table into a 6hp craftsman shop vac. Collection thru the fence is great, collection thru the table is 'acceptable'. *S* more of a design issue I believe than a mechanical one.
Skipper the Penguin
post #6 of 11 (permalink) Old 12-12-2011, 09:20 PM
First Name: Skip
Default Poor Incra dust collection
I have experienced the poor dust collection on my Incra system as well. I found that opening up the end opposite of the dust collection port helps improve the air flow and more saw chips get sucked into the hose.
skipmiester is offline
post #7 of 11 (permalink) Old 12-16-2011, 07:38 PM Thread Starter
mjdorsam's Avatar
First Name: MikeD
Skipmiester:
Thanks, and I had wondered about this for some time, but never tried it - I assume you're speaking of the other end of the split router fence(?), opposite the dust collection end. I've tried to conceive of how to emulate the 'behind the fence, at the bit' approach of the Kreg (and others), but have not developed a workable approach.
mjdorsam is offline
post #8 of 11 (permalink) Old 12-16-2011, 09:38 PM
First Name: Alan
I have the INCRA LS-25 Wonder Fence System coupled with an Incra Mast-R-Lift II router lift. I'm very pleased with the accuracy and ease of adjustability on the Y axis (moving the fence to and away from the router bit) and the Z axis (moving the router bit up and down. The X axis (moving stock along the fence into the router bit), on the other hand, is a different story. The right angle attachment does not move smoothly and feels like it may tip over as it wobbles along the fence. I replaced the two plywood feet with some UHMW material to reduce the drag; also fine-tuned the plate-to-table plane to eliminate a nano-meter high bump that was hanging up the movement of the right angle attachment. There is still drag along the fence due to the nylon screws scraping along the notched teeth that are there to lock down the stops. Placement of the stops is mostly manual; fine tuning of the stops can only be done by turn a phillips head screw. All of this combines to put accuracy and adjustability along the X axis in a class far below those on the Y and Z axis. I guess the engineers at INCRA got burnt out on the project two-thirds of the way through.
Gato9 is offline
post #9 of 11 (permalink) Old 12-19-2011, 07:53 PM Thread Starter
mjdorsam's Avatar
First Name: MikeD
Regarding the right-angle incra jig, I prefer to use something homemade, rather than the incra attachment. By and large, I don't have the riser attachment or other bolt-ons which came with the Wonderfence package. Since my setup is a Table Saw/Router Table arrangement, I've tried to keep a most common denominator between the router and TS setups - this means very few of the router attachments are used - I use the split fence, which slides on easy enough (though, I sometimes forget to screw-down all four mounting screws), and the dust collection connection is put in place from the fence to my stationary DC run. My thought is by separating this, I'll be more focused on the work.
mjdorsam is offline
post #10 of 11 (permalink) Old 12-20-2011, 04:15 PM
Mike Wingate's Avatar
First Name: mike
I really love my Incra,I have improved the right-angle jig, and use it with a Jessem router lift and my DW625.
Mike Wingate is offline
Router Lifts: Incra SWHD vs. Incra PRL-V2 Gato9 Tool Reviews 3 09-23-2011 05:14 PM
Router Lifts: Incra SWHD vs. Incra PRL-V2 Gato9 General Routing 0 09-23-2011 08:14 AM
Incra TS systems TwoSkies57 TwoSkies57 Gallery 5 07-06-2011 07:09 AM
Sold: Incra Router Table Fence LS 17" Joinery System Mahogany Man Woodworking Classifieds 1 11-09-2008 09:01 AM
Incra Systems Zappa Table-mounted Routing 8 05-02-2007 12:35 PM
