moter burn out - Router Forums
post #1 of 3 (permalink) Old 12-07-2011, 12:01 PM Thread Starter
First Name: Rob
Default moter burn out
I had a porter cable 7518 in a rockler lift fx, dust colledtion both in the fence and under table by the moter but after limited use the moter burnt up. What do I need to do to make sure this doesn'f happen with my next router?
foamertwo is offline
post #2 of 3 (permalink) Old 12-07-2011, 12:21 PM
Hi Rob
Many put the router in a box under the top that's a big error, the router needs air to keep cool...you can run the big PC routers and they get HOT in short order..
You can keep the router in a box but it will not last to long.so to say open up the box on both ends, it's just the nature of the router to make dust but not to work in a BOX, take a look at some of your other tools most of them will have the motor out in the open so to speak,,,,,,
post #3 of 3 (permalink) Old 12-07-2011, 06:16 PM
AxlMyk's Avatar
You could always add a 4" piece of flex hose to supply fresh air from the outside of the box, to the air inlet of the router, or top.
AxlMyk is offline
Burn marks on Cherry end grain RJH Wood Species 2 03-15-2011 03:06 AM
burn baby burn...... lathman Pyrography and Carving 14 05-24-2010 10:05 AM
Burn marks rosq General Routing 5 10-31-2007 07:03 PM
Burn burn New Member Introductions 3 12-23-2005 11:38 PM
Burn Marks TOMW. Table-mounted Routing 3 10-02-2005 02:55 AM
