Lift for Bosch 1613EVS - Router Forums
post #1 of 12 (permalink) Old 12-07-2011, 07:35 PM Thread Starter
First Name: Dale
Default Lift for Bosch 1613EVS
I am looking for a lift for a Bosch 161EVS. I haven't found any lifts advertised for this router. It is rather old. The diameter of the motor is 3.5".
Can it be fit to one of the newer lifts on the market? Any help would be greatly appreciated.
Thanks,
Dale
vermontdale is offline
post #2 of 12 (permalink) Old 12-07-2011, 08:01 PM
Thanks,
Dale
Welcome to the router forum, Dale
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 12-07-2011, 09:48 PM
Thanks,
Dale
Hi Dale - Welcome to the forum
The new MLCS motorized lift is sized for the 3.5" motors. I think the Jessum and Kreg lifts have optional "pads" to adapt their lifts.
John Schaben
jschaben is offline
post #4 of 12 (permalink) Old 12-07-2011, 10:29 PM
Hi Dale
Why not use the one built in the router ?
"The fixed base's advanced bit height adjustment system allows you to conveniently adjust the bit height from above the router table."
http://www.routertechnologies.com/fitpage.htm
Thanks,
Dale
post #5 of 12 (permalink) Old 12-08-2011, 02:11 AM
Dale, see the first photo below; that is a Bosch 1613EVS. Is this the router you are asking about? The second photo is a 1617EVS, the third is an old 1601 stuck in a PC base with it's normal base on the right. The 1617 and the 1601 are both 3-1/2" OD. Adapters are available to use these two in lifts.
post #6 of 12 (permalink) Old 12-08-2011, 04:13 AM Thread Starter
First Name: Dale
Thanks for the responses. I will do some more research based on your comments.
This is my first post on this site and I am impressed with the great messages.
Dale
post #7 of 12 (permalink) Old 02-04-2014, 02:57 PM
kincfu's Avatar
First Name: Kin
I have a 1613 and I did not know it can be adjusted from the table top. I guess I have to read through the operation guide. Thanks
kincfu is offline
post #8 of 12 (permalink) Old 02-04-2014, 03:42 PM
The 1613 can not be adjusted from above the table.
post #9 of 12 (permalink) Old 02-04-2014, 07:06 PM
kincfu's Avatar
First Name: Kin
Thanks for the quick reply. I am rather new in wood working. Someone suggested using a scissor jack to make router lift. Will it work?
Kin
kincfu is offline
post #10 of 12 (permalink) Old 02-04-2014, 08:21 PM
I'm still using one too. I don't think the motor housing is round, but as many times as I have used it, I've never had the motor out of the base.
Putting that 1601 in a PC base is a good idea. I bought two of those routers reconditioned over 20 years ago I think, and those bases were the most impossible to adjust that I've ever seen. Maybe I should offer them cheap to anyone who just wants the motor to put in a lift-but buyers would have to get the motor out of the base. I never used them to amount to anything because you simply cannot fine adjust them.
Tom King is offline
PRL-V2 Router Lift DarkFlame Starting Off 8 03-20-2011 08:01 PM
Router lift for Freud FT3000vce? Tuthmose Table-mounted Routing 12 12-10-2010 10:35 PM
Router lift DougO General Routing 8 08-18-2010 10:53 PM
Rousseau 3002 Router Lift LS 46_trap Table-mounted Routing 2 02-18-2008 07:59 PM
