Add guide pin to DIY table? - Router Forums
post #1 of 3 (permalink) Old 12-14-2011, 05:26 AM Thread Starter
First Name: Ron
Default Add guide pin to DIY table?
Any thoughts on adding a guide pin to a DIY router table? Bolt thru the table? Distance from the router?
Thanks in advance!
Ron
rpludwig is offline
post #2 of 3 (permalink) Old 12-14-2011, 08:33 AM
AxlMyk's Avatar
My pin is about 3" from bit center. It fits in a hole in the insert.
AxlMyk is offline
post #3 of 3 (permalink) Old 12-14-2011, 12:05 PM
Ron, take a look at the first sticky thread in this section or watch the video on building the VacGuard. This works as a starting pin, a bit guard, added light on the work area and gives you excellent dust collection.
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
diy wooden X-Y table and rotary head SparkyOR Jigs and Fixtures 28 02-10-2012 10:10 AM
Custom Ellipical Poker Table AzViper Show N' Tell 29 01-21-2012 02:41 PM
DIY solution to guide bush size issue charlesb General Routing 6 08-25-2011 05:31 AM
