TS/RT Extension; Cast or other? - Router Forums
post #1 of 6 (permalink) Old 12-14-2011, 01:09 PM Thread Starter
First Name: Tim
Default TS/RT Extension; Cast or other?
Hello all. 1st question. Should I mount a Cast iron table extension on my old Craftsman table saw or build one out of plywood/ particle board? I have a home built RT, but am limited with my space. I would really like to find an old cast iron TS extension for my saw as I know craftsman had them, but they are hard to find. The Benchdog and others are really expensive and I have read mixed reviews about them fitting my saw. Any help would be much appreciated. Thanks, Tim
Rd2nowr is offline
post #2 of 6 (permalink) Old 12-14-2011, 01:27 PM
First Name: Michael
This is really a matter of preference. The cast iron, like the Benchdog is very heavy. This is a mixed blessing. On one hand it is hard to mount and difficult to modify. On the other hand, the sheer weight can be a benefit to the saw, in that the additional weight will reduce vibration. They are, as you mention, a bit pricy. One made from MDF like Incra's more easily installed and modified.
I was going to add a router table to my Rigid table saw. My choice was going to be the Benchdog table. I was also considering the Benchdog lift kit for the table. As it happens I am now going to build a stand alone router table. Moving forward, I plan to install a Incra Conbo kit. But for now I am going to stick to just the one router table because, as I like to point out, I have to still feed the little black and white fella you see to the left of this post.
theexpozay is offline
post #3 of 6 (permalink) Old 12-14-2011, 02:21 PM
Hi Tim
This just my 2 cents , just make one out of some good plywood but forget the particle boards that stuff is just nasty to work with and to use for a router table...
You don't need a tank of a TS extension to hold a router..or a aircraft table top for just a router............
post #4 of 6 (permalink) Old 12-14-2011, 02:36 PM
I guess I have kind of decided to do both but not at the same time. Like one of the other posters, I also have the Ridgid 3650 TS. I am actually going to be building an entire mobile TS workstation with a router table extension. What I am planning to do for the first phase of the project is to put a laminated MDF top between the fence rails to the right of the saw. It will rest on top of and be fastened to a router cabinet below it, not to the rails or TS top. All of that will sit on a mobile base. Then when I have a little more budget I do plan to replace the left side TS extension wing with the bench dog cast iron top.
Tom5151 is offline
post #5 of 6 (permalink) Old 12-14-2011, 02:56 PM
Cast Iron Router Table Extension and Fence
http://www.mlcswoodworking.com/order...0extension.pdf
post #6 of 6 (permalink) Old 12-23-2011, 09:37 PM
jamesamd's Avatar
First Name: james
I would not try to use a TS extension as a mounting place for a router.The ribbing under the table,will make the effort almost impossible.
Even if You have access to a mill to create the mounting surface and the opening,removing any part of the ribbing,will likely cause the extension to warp from the stress that was contained,being relived.
Jim
jamesamd is offline
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router Table Extension - Attachment and Alignment GarethR Table-mounted Routing 1 11-20-2009 12:47 AM
Craftsman table saw extension ccmnova Table-mounted Routing 1 11-03-2009 07:59 PM
BlackJack Cast Iron Extension Router Wing Puzzline Table-mounted Routing 18 04-21-2009 01:53 AM
MLCS Router Bit Extension dimensions cadcraig Starting Off 4 08-27-2008 01:33 AM
