how to calculate drawer sizes? - Router Forums
post #1 of 3 (permalink) Old 10-16-2004, 10:05 AM Thread Starter
Default how to calculate drawer sizes?
Does anyone have a 'simple' way to calculate the sizes of the pieces for drawers to come up with the finished size to fit a certain drawer opening taking into consideration different widths of wood? I am having a problem with this. I can't get a finished drawer to "fit the whole" properly. I don't mean calculating for slides, just the actual drawer.
thank you and have a good day.
glassguy1456 is offline
post #2 of 3 (permalink) Old 10-16-2004, 12:32 PM
The Router Guys
BobandRick's Avatar
To figure the parts to the drawer I first need to know what type of joinery your going to use.
Having said that for this example, I will assume we are using a simple drawer construction with a rabbet joint on a sub-front, dado for the back and the groove for the bottom. The drawer front will mount on the sub-front after the hardware has positioned the drawer.
All rabbet, dado and groove joints are cut to a depth of 1/2 the material thickness. This is because two halves equal one material thickness and the amount you need to minus from the overall width of the drawer is then one material thickness to make the joinery work. For this example the groove is set in 5/8", which determines the width of the back. Note: the groove position is determined by your hardware.
Example: Drawer sample: 4" X 12" X 24"
The overall width of the drawer is 12", depth is 24" and height is 4", the thickness of the drawer sides, sub-front and back is 1/2": You need to minus 1/2" from 12", which equals 11 1/2" for the length on the sub-front and back. The width of the back is determined by the 5/8" groove position.
Parts list is as follows:
width Length Thickness
1 - sub-front 4" 11-1/2" 1/2"
2 - sides 4" 24" 1/2"
1 - back 3 3/8" 11-1/2" 1/2"
1 - Bottom 11-1/2" 23 3/4" 1/4" Plywood
It is now your turn...
Make the list of materials for the following drawer: 6" X 14" X 24"
Then make the list of materials with 3 other drawer sizes of your choice.
Rick and Bob
The Router Guys
On January 17th, 2020 Dad passed Away at the age of 87 and I will miss him very much. If anyone is interested there is a memories website https://memories.routerworkshop.com/
BobandRick is offline
post #3 of 3 (permalink) Old 10-17-2004, 03:03 PM Thread Starter
Thank you, gentleman, this is a place to start and I will give this a try. (somewhere to start for me)
Have a good day and again, thank you for your quick response and help.
Metric shank sizes? Gusbub Router Bits - Types and Usage 16 02-12-2008 10:02 AM
Drawer Pull Jig curiousgeorge Jigs and Fixtures 11 02-05-2007 10:44 AM
EZ Link DougO New Member Introductions 2 03-09-2006 12:52 PM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 10:20 AM
