quicker collet for bit changes? - Router Forums
post #1 of 13 (permalink) Old 12-22-2011, 05:23 PM Thread Starter
Default quicker collet for bit changes?
First post, let me jump in with some questions..
I picked up a used bosch 1617 in a woodpecker lift, in an incra table w/ ultra jig. I dove in and started with their symetrical box joint template. Seems like it's going to work well, but I hit a couple issues:
I was using the the 'shop-stop' incrementaltools.com/INCRA_Shop_Stop_p/shopstop.htm and noticed the leading edge (not the red stop barK, but the gold part that mounts on the fence) protrudes slightly proud of the fence, and caused the parts to deflect a bit or bump when they came in contact. Not sure how I messed that up, it's a couple of plastic screws holding it to the fence. Anyone here ever had that problem? Prob a newb issue, but that's why I ask.
Next thing- had to change the bit. -DISCLAIMER- This next part will prob will get me beat up -DISCLAIMER- but 2 wrenches (16mm, 22? used adj wrenches) was hard to do reaching under the table, and easier but annoying above it. Are there special wrenches (thin?) for this? My other router is a festool 1400, and it has this nice clicky ratchet and one wrench. Any kind of quick change collets I could put on the bosch 1617?
I had some blowout on the front box side (1/2" baltic birch ply) initially, but I read though the directions (who knew they were useful?) and it said not to do the full height in one pass. Workflow question- do you just mark the finished height line on the pieces and then sneak up on them for the last pass? Seems like the more times you move the bit up and down the less repeatability you have.
I know, I know- new guys.
mrpedal is offline
post #2 of 13 (permalink) Old 12-22-2011, 10:07 PM
Hi Mike - Welcome to the forum
Sorry, I can just help with the wrenchs, items 150 and 151... doesn't indicate which is which:
Bosch 1617 Parts List and Diagram - (0601617039) : eReplacementParts.com
The "clicky" ratchet is more than likely a spindle lock device and not in the collet. I don't know if the newer 1617's have it or not. Even if they do, I doubt it will be retrofittable, at least not economically.
John Schaben
jschaben is offline
post #3 of 13 (permalink) Old 12-23-2011, 05:57 PM
First Name: Dennis
I just read about a new product called Musclechuck in Fine Woodworking that attaches to your collet. You then use an Allen wrench to remove your bit. They did it in 7 seconds. Available from Woodrat apparently.
denniswoody is offline
post #4 of 13 (permalink) Old 12-23-2011, 06:14 PM
Hi Dennis
I think you will find that the collet must be removed and then you install the quick chuck..have you every rounded out a Allen device ?, and it must real tight to hold the router bit, it can be a real Pain to free it up, once you do. I still have a router bit stuck in the one I have in the tool box
Google
http://www.routerforums.com/general-...cle-chuck.html
post #5 of 13 (permalink) Old 12-24-2011, 11:33 AM
First Name: Dennis
Yes, to clarify it replaces the collet. Poor wording on my part. I am not recommending this, just passing along some info from FWW.
post #6 of 13 (permalink) Old 12-24-2011, 11:47 AM
Hi Dennis
Just one user review..
Got it . I got the one I have back in 2007 or 2008 I don't recall for sure just one of the things that looked real good at the time but it did turn out to be real night mare.. ( for Porter Cable router)
I knew I could get the Allen out in time with some heat but it looked like a bad design and not way to over ride it..
http://www.woodcraft.com/Product/200...side-9720.aspx
I got the have from Rockler but they don't list them anymore.
post #7 of 13 (permalink) Old 12-25-2011, 02:07 PM
TheOakDude's Avatar
First Name: Paul
hi there,
check out the rather expensive precision collet ext from rutlands.
The moving finger writes....and having writ moves on...nor all thy piety nor wit shall lure it back to rub out half a line.
TheOakDude is offline
post #8 of 13 (permalink) Old 12-26-2011, 03:57 AM
Mike Wingate's Avatar
First Name: mike
Can you use cranked spanners. I made a pair for my table, I only need to use 1 as there is a spindle lock that requires a thumb. I have an ultra and really like it once it is set up. I do my finger joints in multiple passes and use waste sacrificial pieces front and back. I have altered my right angle fence for better operation by replacing the laminated feet with slippy plastic ones. Once the jig is set up I will carry out multiple boxes, one set of sides at a time. The biggest boxes were 3'x3'x2' for my daughters stage set models in 6mm MDF. Cutting the joints was fine, the assembly was time consuming. Make sure you have the correct size bits It took 3 purchases from different makers till I found the perfect fit.
Mike Wingate is offline
post #9 of 13 (permalink) Old 12-26-2011, 09:35 AM
ethylplant's Avatar
I have been using this extension / quick collet for a month or so now (see link). It is ok, but you have to mount a spacer on the bottom of your router (between the plate and the table). It also limits the travel DOWNWARD of a bit, which can make using a spiral bit useless with this collet extension, unless you want more than an inch of the bit ABOVE the table top when routing. It does work great for roundover type bits, but not well at all for straight bits.
I only went to this when the shaft lock on my Porter Cable router broke. It is difficult to use two wrenches to loosen/tighten the collet nuts, but I think I will go back to that method and get rid of the quick collet / extension.
Just my humble opinion...
Router Xtreme Xtension™ - Rockler Woodworking Tools
ethylplant is offline
post #10 of 13 (permalink) Old 02-21-2013, 12:21 PM
The Musclechuck doesn't have a cam to indent the tool shank. It is the cam in the cam chucks that causes all of the problems. When the cam is overtightened the cam indents the toolshank causing a burr which jams the tool shank in the chuck. Check out the specs on the musclechuck web site. Good luck!!
Johnd426 is offline
Jacob's Power Collet Questions cdevlync General Routing 5 10-20-2010 11:07 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
