incra router top dimensions - Router Forums
post #1 of 6 (permalink) Old 12-22-2011, 07:05 PM Thread Starter
First Name: mike
Default incra router top dimensions
I'm building a router table for a Incra Positioner system and in need of some dimensions. I need to know the distance from the center of the bit to the edge of the table parallel to the fence, and the distance from center bit to the mitre slot. both of these from a incra toble top. Also will that mitre slot dimension work with most coping sleds, or will the Incra system handle coping door rails too?
yammi450 is offline
post #2 of 6 (permalink) Old 12-22-2011, 07:45 PM
Welcome to the router forum.
Thank you for joining us, Mike.
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 12-22-2011, 07:55 PM
Cassandra's Avatar
First Name: Cassandra
Hi Mike:
Welcome to the Router Forums!
http://www.incra.com/manuals/LS_Manual_2010.pdf
The suggested positioning is on Pages 5 and 6.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #4 of 6 (permalink) Old 12-22-2011, 09:38 PM Thread Starter
First Name: mike
That only tells me where and how to mount the positioner. I'm looking to cut the hole for the router plate, and dado for the mitre slot. My table is the same as Incra's 27" x 43" and I figured I'll match there table.
yammi450 is offline
post #5 of 6 (permalink) Old 12-23-2011, 06:18 PM
First Name: Duane
My Incra top measures 26 3/4 x 43 3/8. 5 3/16 from edge of top to first edge of track.
7 3/8 from edge of top to opening of plate. That is for the offset top 27x43 as in there combo 3. If you need any more let me know.
D.C. is offline
post #6 of 6 (permalink) Old 12-23-2011, 07:07 PM Thread Starter
First Name: mike
Thanks Duane. Thats the info I needed.
yammi450 is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Grumble - How to remove snapped screw from router table top? xvimbi Table-mounted Routing 14 02-21-2010 05:04 PM
