Overhead routing - Router Forums
post #1 of 4 (permalink) Old 10-16-2004, 10:17 PM Thread Starter
Question Overhead routing
I have seen a radial arm saw that can take a router for overhead work but wondered if there is a stand available to hold a router above the work.
I have found a table which can be wound forwards and backwards and side to side which is really intended for a small milling machine.
As I am a skilled toolroom miller I can see many advantages of mounting a router overhead.
When I was at work I often took wooden workpieces into work to cut on my machine during lunch breaks.
It would be nice to do the same in the workshop.
When cutting housings (dados) a few turns of the handle and it would be done.
A known distance for each turn (1/10") would enable very accurate cuts to be made.
Dewy is offline
post #2 of 4 (permalink) Old 10-17-2004, 09:46 AM
reible's Avatar
Hi,
Nice to here from someone who has worked in the tool room! I did a little of this a lot of years ago and have used mills for woodworking. Anyway I started a thread on this same basic subject a while back. Please take a look at:
www.routerforums.com/showthread.php?t=122
I am still thinking of mouting a router on a drill press and using the quill as the vertical feed and then maybe getting an x-y table to use for the other directions if I could find one cheap enought..... The issue with making one would be the threads per inch...
Even without the x-y table I can see it being usefull by adding a pin below on the table and a template on the bottom of the work piece to control where you route.
Anyway take a look at the other posting,
Ed
reible is offline
post #3 of 4 (permalink) Old 10-17-2004, 09:36 PM
I'm a Cnc programing machinist and do woods on my free times using those cnc machines. Yes those endmills do put out a glassy smooth finish. I had fun building a wooden golf putter on it.
Bluegillman is offline
post #4 of 4 (permalink) Old 10-18-2004, 03:35 PM Thread Starter
I must be losing my memory in my old age reible.
I was one who replied to your other post on the subject.
A router mount on a drill stand sounds better to me.
Being able to use the quill gives far more scope.
X-Y axis tables have their uses but an X-Y-Z axis would be much better (but far more expensive)
Every home use hobby mill I have seen only has X-Y on the table.
How I'd love a Bridgeport J head mill at home.
What scope with a 36" x 15" table travel.
Unfortunately they run on 415v 3 phase which is highly expensive to install at home, if at all.
The height is also about a foot higher than my flat roof.
Dewy is offline
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Freehand routing Visteonguy General Routing 53 07-12-2013 04:33 AM
wood residential and business sign routing with mark disaverio New Member Introductions 10 06-07-2013 11:55 PM
Dust Colection for routing Dados KentWW Table-mounted Routing 3 01-10-2007 02:18 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
