Router table build help! - Router Forums
post #1 of 7 (permalink) Old 12-28-2011, 08:33 AM Thread Starter
rrg
First Name: RICK
Default Router table build help!
I'm brand new, so patience may be required. Looking to build a bench system. In order to save $ for project I'm thinking of making the table. I plan on using an Incra mast-r-lift 2 with a PC 7518, & leaning towards a Woodpecker super fence eventually .My concern is getting the plate cut out right. I saw an Incra plate template from I believe woodcraft, but not sure of the best way to go about it. I have a PC 690 with a fixed base and all the saw's etc. How do you get the shelf bevel, & leveling screws right. Thanx in advance!
rrg is offline
post #2 of 7 (permalink) Old 12-28-2011, 09:05 AM
papawd's Avatar
First Name: warren
Welcome Rick
papawd is offline
post #3 of 7 (permalink) Old 12-28-2011, 09:24 AM
Welcome Rick.
When you machine for the shelf that the plate rests on you can use a rabbiting bit after you machine for the size of the plate with a mortising bit (straight cutter with a top bearing) . As far as leveling the plate to the table use a straight edge & adjust the leveling screws till the plate is level with the rest of the top. Don't want your material to catch on the edge of the plate as your material slides over it. You might have to use locktite to keep the screw from moving from the vibration during use. Don't use red. I use blue because I may want to adjust them later.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 7 (permalink) Old 12-30-2011, 05:17 AM Thread Starter
rrg
First Name: RICK
I wimped out & spent $$$. Found a woodpecker kit that was so pretty. Red, silver, shiny, DONE! I really wanted the Incra Mstr. Lift 2, but they wouldn't break up the pkg. So I've got the PRL-V2. I hope the thumb wheel isn't as hard to rotate as a few have said, or the backlash / accuracy. I'll report when it's up & running.
rrg is offline
post #5 of 7 (permalink) Old 12-30-2011, 10:36 AM
Nothing wrong with buying over building. For many it gets them working quicker. Sometimes because of the weight of the router, adjustments lowering the bit will cause some backlash. If this is a problem you can lower past the setting you want & raise the bit up to where you want it. This way you are fully supporting the weight of the router as you adjust up.
Whittier, CA.
jlord is offline
post #6 of 7 (permalink) Old 12-30-2011, 05:27 PM Thread Starter
rrg
First Name: RICK
Thanks for the advice jlord, unfortunately I traded painting the bedroom for my toy so I'm behind schedule. But eventually.......!
rrg is offline
post #7 of 7 (permalink) Old 12-30-2011, 05:40 PM
TwoSkies57's Avatar
Hey Rick, welcome to the community...
you'll love the PRLv2... the thumb wheel can be a bit touchy, but nothing you can't live with. Just be sure to NOT over tighten the brake. I use just a touch of pressure on mine and it locks things in place just fine.....
accuracy is freaky good!! James called it with any backlash issues,, just lower and sneak 'up' on it....
Skipper the Penguin
TwoSkies57 is offline
New Router Table flemingj1122 Table-mounted Routing 13 05-19-2012 03:02 PM
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
