bosch mrc 23 - Router Forums
post #1 of 3 (permalink) Old 12-28-2011, 02:24 PM Thread Starter
Default bosch mrc 23
anybody know what the motor diamiter is or if the cheaper jessem lift will fit thanks
dogrunner is offline
post #2 of 3 (permalink) Old 12-28-2011, 05:12 PM
The Bosch "23" will not work in any lift, it will only work in its own bases because of the external 5 volt power bus. See the bump out in the photo where the Bosch name is? You can see the bus in the fixed base. No need for a lift with this router, it has a built in above the table adjuster... the same as the later 1617 bases. If you want to use Bosch in an after market lift the 1617EVS is your only option.
post #3 of 3 (permalink) Old 12-28-2011, 10:14 PM Thread Starter
thanks for the info cant find a lot of info on that router
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 25 01-19-2012 09:44 AM
Dewalt or Bosch??? jrwoodbutcher Starting Off 5 12-23-2010 10:18 AM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
Bosch Thread Router Template Adapter/Porter Cable megreene Router Bits - Types and Usage 4 12-26-2008 11:36 PM
