Triton TRA001 Router Raizer Installation Instructions - Router Forums
post #1 of 6 (permalink) Old 12-29-2011, 09:03 AM Thread Starter
First Name: Steve
Default Triton TRA001 Router Raizer Installation Instructions
Hi,
I have an older Triton TRA001, which doesn't come with the above table raiser adjustment. I understand that Router Raizer make a retrofit which works for this particular router. Does anyone happen to have a copy of the instructions that come for this model?
I am thinking of buying the router raizer but would like to do a bit of reading on what is involved in fitting it to the existing router before I buy it.
If anyone can help, I would really appreciate it. I'm building a couple of tables (one for me and one for my Dad) and we both have the same routers. I've attached an early pic of the top construction (old pic while just starting the project). I'll post more as I get the carcass finished and everything assembled.
Many thanks,
Steve
Name:	Router Tables 003.jpg
Name:	Router Tables 035.jpg
Name:	Router Tables 034.jpg
Name:	Router Tables 036.jpg
Geordie99 is offline
post #2 of 6 (permalink) Old 12-29-2011, 09:47 AM
Hi Steve they have instructions for a TRC001. Here's also a link to their instructions page.
Instructions for installation
File Type: pdf Triton TRC001 Router Raizer instructions.pdf (3.04 MB, 426 views)
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 6 (permalink) Old 12-29-2011, 09:54 AM Thread Starter
First Name: Steve
Thanks James! Just what I was looking for.
Cheers,
Steve
post #4 of 6 (permalink) Old 12-30-2011, 06:31 PM Thread Starter
First Name: Steve
Well, I went ahead and ordered one and what a deal!!! It is NOT a typo.
Router Raizer
Thanks again for the help James. Should be perfect for the new table.
Cheers,
Steve
post #5 of 6 (permalink) Old 12-30-2011, 08:32 PM
First Name: downhill
I installed a router raizer in my Triton. It works like a champ.
As to installing it, just take your time and make sure you understand the instructions for each step. It's not difficult but a bit time consuming.
It'll come with some lock washers.. I used the extra spacers to push the one on that has to slide a ways. It'll keep you from damaging the washer.
downhill is offline
post #6 of 6 (permalink) Old 06-25-2014, 12:47 AM
First Name: Nathan
This thread is a bit old now but thought the question still may be valid.
How does this router raiser work with the bit lock engagement on triton routers?
So when you put the handle in and wind it up to change the bit above the table does it still engage the spindle lock to use the spanner and change the bit? then it dis engages when you wind it back down?
Same as the OP just after some more info before buying it for my TRA
Thanks all
delbs is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
For Sale: Triton TRC001 3-1/4 HP Router oldhippie1951 Woodworking Classifieds 0 08-15-2011 01:30 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Triton Router Warenty zebu5 General Routing 3 06-23-2009 12:50 PM
Triton TRA001 istracpsboss Table-mounted Routing 15 04-20-2009 08:52 AM
