Triton TRA001 Yay or Nay? - Router Forums
post #1 of 8 (permalink) Old 12-29-2011, 10:38 AM Thread Starter
Default Triton TRA001 Yay or Nay?
I'm thinking about picking up the Triton TRA001 while they are on $199 clearance. I've never used one of these routers so I'm looking for some input on the router. I will primary use it in a router table but I man occasionally use it free hand. Are these pretty good routers for $199 or is there something better for that price? If possible id like one with a built in lift (I dont think the triton has one...correct me if I'm wrong)
guitardemon is offline
post #2 of 8 (permalink) Old 12-29-2011, 10:51 AM
Hi. The new Triton's have a built in lift with above table adjustment. I have a Triton TRC001 in one of my tables & it works well as a table mounted router. I have never used it freehand as I have many other routers for that so it has been mounted in the table since I bought it. The model your looking at might be an older model without the above table adjustment. You would have to reach under to make adjustments when table mounted unless it was mounted to a base plate you could lift out.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 8 (permalink) Old 12-29-2011, 11:01 AM Thread Starter
When you say new routers, dose that include the one on clearance at woodcraft: Buy Triton 3 1 4HP Plunge Router at Woodcraft
or do you mean the newer version of that router comes with a lift?
post #4 of 8 (permalink) Old 12-29-2011, 11:07 AM
I think that is the older model. The newer models come with a built in lift you can adjust from above the table. Mine is the Triton TRC001 3-1/4hp.
Whittier, CA.
jlord is offline
post #5 of 8 (permalink) Old 12-29-2011, 01:16 PM
it says it comes with a winding handel for above the table ajustment i hope it does i just ordered one
dogrunner is offline
post #6 of 8 (permalink) Old 12-29-2011, 02:02 PM
First Name: downhill
Yep it clearly states.....
Product Information:
Also included is a winding handle so you can adjust bit height from above your router table in 1/128" increments
I have an older model that I added a razier lift to. I love mine.
downhill is offline
post #7 of 8 (permalink) Old 12-29-2011, 03:31 PM
On the WoodCraft web site it says it is a TRC001 not a TRA001 so you should be fine & receiving the newer model.
Whittier, CA.
jlord is offline
post #8 of 8 (permalink) Old 12-29-2011, 04:46 PM
i hope they ship fast i hate waiting
Triton TRA001 Router Plate GJP60 Table-mounted Routing 41 01-10-2015 05:28 AM
Triton TRA001 Router Raizer Installation Instructions Geordie99 Table-mounted Routing 5 06-25-2014 12:47 AM
Confused about Triton TRA001 papaworx General Routing 10 12-20-2010 11:16 AM
Triton TRA001 JeffMartin New Member Introductions 6 01-26-2010 08:39 AM
Triton TrB001 and TRA001 Harmony New Member Introductions 13 09-12-2009 08:31 PM
