splintering - Router Forums
post #1 of 3 (permalink) Old 10-16-2004, 10:56 PM Thread Starter
Default splintering
when i cut using a mold trim bit, it always splinters on the corners when i cut across the grain.
how can i prevent this?
i'm using a table router sys
thank you anyone
merrell
Merrell is offline
post #2 of 3 (permalink) Old 10-16-2004, 11:24 PM
ejant's Avatar
First Name: Ed
Make your cross the grain cuts first the with the grain. This will clean up any tear out.
ejant is offline
post #3 of 3 (permalink) Old 10-17-2004, 09:34 AM
reible's Avatar
thank you anyone
merrell
ejant is correct you need to do an end grain first then rotate the piece and do a with the grain cut followed by the next end grain and lastly the side with the grain.
Now if you still have problems things to check for are a dull bit, taking to heavy a cut but give above mentioned method a try and get back to us if you are still having problems.
Ed
reible is offline
