Edge start round -nosed bit? - Router Forums
post #1 of 4 (permalink) Old 01-05-2012, 06:05 PM Thread Starter
First Name: Andre
Default Edge start round -nosed bit?
Can a round nosed bit be started at the edge of a board, as in cutting a groove lengtwise in , say, a 6 inch board ? I have to laminate 2 pieces of 3/4 wood, 4 x 6inches square, and then drill a 3/8 inch hole through the centre of the lamination for a 3/8 bolt. I thought it would be easier to route a groove in both boards before laminating, but I have read that this type of bit should be plunged into the wood. Any advice "wood" be appreciated! BigGuy
BigGuy436 is offline
post #2 of 4 (permalink) Old 01-05-2012, 06:24 PM
Hi Andre - Welcome to the forum
No reason you couldn't start at the edge with a roundnose bit. The job you're describing I would certainly do it that way.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 01-05-2012, 06:35 PM Thread Starter
First Name: Andre
Thanks, John, better to ask, than to receive a board in the face!
post #4 of 4 (permalink) Old 01-05-2012, 09:25 PM
TWheels's Avatar
Wow! do you ever have that right!
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Newbie installs a mounting plate using one bit... matt1710 Table-mounted Routing 11 01-03-2013 02:34 AM
bit for edge gluing jerry.s Router Bits - Types and Usage 5 06-22-2011 08:38 PM
1/2" round over bit won't fit Blind Bruce Table-mounted Routing 6 01-18-2007 07:28 PM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
