Torsion Box required - Router Forums
post #1 of 5 (permalink) Old 01-11-2012, 06:24 PM Thread Starter
paduke's Avatar
Default Torsion Box required
I have a large table. 36"X30". I do not wish to debate the merits of why I wanted a top that big but realizing others might also I suggest building a torsion box to support it if you do. The attached PDF shares how my top became a bowl. It also shows my top with torsion box installed.
paduke is offline
post #2 of 5 (permalink) Old 01-11-2012, 10:32 PM
A large top has just as many merits as a small one. Just different ones.
post #3 of 5 (permalink) Old 01-12-2012, 11:17 AM
AxlMyk's Avatar
2 ways to do a top without a torsion box.
I used 2 3/4" MDF 24"x36". I glued them together with the convex sides together. )(
This cancels out any warp.
Steel stringers between the pieces will stiffen up any top. Like the one I made for my RAS.
AxlMyk is offline
post #4 of 5 (permalink) Old 01-12-2012, 01:25 PM
BigJimAK's Avatar
Bill,
There's no reason to apologize for your choice of router table size; mine is 30"x52". I chose that size for four reasons: (1) it takes full advantage of the capabilities of my fance, (2) it holds 2 routers, (3) it rests on a full-sized rolling base with *lots* of drawers for tool storage (which I *really* needed, and (4) I wanted it that size. <g>
I also recognize that others like much smaller tables; it's a matter of personal preference. What's best for one may not be best for all and everyone here is expected to respect that.
Mine was made by sandwiching 2 layers of 3/4" MDF between layers of Formica. A maple trim was then added. I've attached an old picture of it, before the base was built.
Jim
BigJimAK is offline
post #5 of 5 (permalink) Old 01-12-2012, 07:24 PM Thread Starter
paduke's Avatar
One reason for sharing was the MDF on first table. It had a factory finish which caused the cup after insert plate and miter slot was routed in. As the PDF said I belly bumped 3/4' ply w/the MDF
Not apologiaizing just avoiding the small top advocates. My reasoning was large panels will be more stable.. and an incra positioner as one of the fences (100 bucks craigs list.) Finally its in middle of the shop and in line with TS outfeed
paduke is offline
My first box dkneifel Show N' Tell 19 02-08-2016 08:10 AM
Learning How to Make a Tissue Box Cover learnexperience General Routing 2 12-05-2011 05:56 PM
Another combination plane blade box hack rwyoung Show N' Tell 8 01-10-2011 08:41 PM
Tom Caspar's torsion box workbench Cochese Starting Off 5 02-27-2010 11:25 AM
Beall Tilt Box Versus Wixey Angle Gauge bennybbc Tool Reviews 4 02-04-2010 12:01 PM
