Bosch 1611 - Router Forums
post #1 of 4 (permalink) Old 01-16-2012, 06:46 PM Thread Starter
First Name: Richard
Default Bosch 1611
This may be a shot in the dark, but has anyone ever modified a Bosch 1611 to work under a table? Or for that matter, any of the older plunge routers like that.
mr nobody is offline
post #2 of 4 (permalink) Old 01-16-2012, 08:38 PM
Hi Richard - I'm sure someone has. With most plunge routers you need to remove the springs, especially on the big guys because the springs are necessarilly pretty strong. I believe that most have likely been installed with lifts. Not sure if the Router Raizer lift will work with the 1611 but it seems to be a pretty economical lift, or, the last issue of Shop Notes had plans for a shop built lift that also seems to work pretty well.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 01-16-2012, 11:33 PM
Richard, I sent you a PM with information on removing the springs and a link to the Router Raizer from Rockler. The RZ200 works with the 1619 so it should work with your 1611.
post #4 of 4 (permalink) Old 01-17-2012, 08:48 AM
LexB's Avatar
First Name: Lex
I am using my old Makita 3612BR in a router table. I put a Router Raizer kit on my router, and it works great. I can even use the Router Raizer by hand when using my router hand-held (not very often, but it works fine.) It took me a couple of hours to modify my router, but I went slow and careful, making sure that I understood each instruction before attempting it.
LexB is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 25 01-19-2012 09:44 AM
Dewalt or Bosch??? jrwoodbutcher Starting Off 5 12-23-2010 10:18 AM
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
