offset router collet wrench for Bosch - Router Forums
post #1 of 18 (permalink) Old 01-19-2012, 03:53 PM Thread Starter
First Name: Joe
Default offset router collet wrench for Bosch
I am building a router table and placing a Bosch 1617 in it. I tested everything and It seems to work well so far but for above the table bit changes I will need some offset wrenches. I can find one for the larger collet wrench. The wrench that came with the router is marked 24 and most places sell a 15/16 or a 23.8mm and labeled it for this router.
However the second wrench which holds the spindle is marked 16mm and I can not find one like that.
I know I am not the first guy to install this router and want to make above the table routers so does anyone know where I can find a set of these wrenches. I have already checked Rockler and several other online retailers.
Thanks for your help
UncleJoe is offline
post #2 of 18 (permalink) Old 01-19-2012, 05:13 PM
HI
MLCS Heavyweight and Precision Router Tables
Router Accessories
Amazon.com: Off-Set Router Bit Wrench: Tools & Home Improvement
http://www.amazon.com/Wiha-35015-Ope...2&sr=1-3-fkmr0
http://www.amazon.com/Wiha-35015-Ope...7014518&sr=1-3
post #3 of 18 (permalink) Old 01-19-2012, 07:07 PM Thread Starter
First Name: Joe
Thanks Bob but none of those links or any that I could find offer an offset wrench that will hold the shaft which is 16mm or about 5/8's
Surely I am not the only guy that needs this.
UncleJoe is offline
post #4 of 18 (permalink) Old 01-19-2012, 07:44 PM
Can you put the bend in the wrench you have?
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 18 (permalink) Old 01-19-2012, 08:09 PM
Hi Joe
You must start with something, just pull the torch out and bend it into a "Z" I have 3 or 4 that I have made that way..
Instructions for installation
http://www.routertechnologies.com/in...%20generic.pdf
http://www.routertechnologies.com/in...C%20wrench.pdf
post #6 of 18 (permalink) Old 01-19-2012, 08:47 PM Thread Starter
First Name: Joe
Those Bosch wrenches are pretty stout. I will give it a try. Have you seen the Eliminator RC Quick Change Chuck. At woodpeckers /quickchuck
Are they any good? Might be just the ticket for me.
UncleJoe is offline
post #7 of 18 (permalink) Old 01-19-2012, 08:51 PM
MLCS Router Collet Extension and Review
post #8 of 18 (permalink) Old 01-20-2012, 06:41 AM
Ken Bee's Avatar
First Name: Ken
I just Googled for a bent wrench with no luck naturally. I did see a Bosch wrench and it is flat stamped steel so it shouldn't be all that difficult to shape. In fact you could probably put it in a vise and use a large hammer to beat it into submission.
You may have another out if it will fit and that is a 3/8 drive "crowsfoot" wrench from Sears or ????. Use it with a short extension and a breaker bar.
The MLCS Extensions that Bob pointed out are also nice.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #9 of 18 (permalink) Old 01-25-2012, 07:05 PM
Same issues, was looking for this info as well.
mrpedal is offline
post #10 of 18 (permalink) Old 01-27-2012, 11:23 PM
thadius856's Avatar
First Name: Thadius
The guy who made mine cut into three pieces with a few cut off wheels, then welded it back together. Works great.
thadius856 is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
New router use w/ Ryobi 1801M1 router 1/4 inch collet RexM Router Bits - Types and Usage 1 04-11-2011 04:37 PM
Stuck collet on router - help tkm795 General Routing 5 01-13-2011 08:53 PM
Router Collet DAWILLIAMS General Routing 6 01-10-2011 10:39 PM
