should i upgrade? - Router Forums
post #1 of 4 (permalink) Old 01-27-2012, 05:44 PM Thread Starter
Default should i upgrade?
Ive got a DW 616 that ive used freehand in remodeling work for the last few years. Im planning on starting to do more woodworking and id like to get a router table as well.
Will this be a good router for a table? I dont want to go buy base plates, etc for this and then just end up replacing the router a few weeks later. I dont plan on doing a ton of work, but definitely want a solid router that i dont have to worry about or finesse, and im not clear if the 616 is up to the challenge.
rfsurfer is offline
post #2 of 4 (permalink) Old 01-27-2012, 06:13 PM
Talking
Welcome Rfsurfer
If you have the means to upgrade to a PC7518, by all means go for it.
It will last you so long, and it's worth the investment.
Good luck on your choice.
waho6o9 is offline
post #3 of 4 (permalink) Old 01-27-2012, 07:08 PM
MEBCWD's Avatar
Welcome Rfsurfer,
The DW 616 is a transition between the laminate trimmers and the mid size routers.
I would get a more powerful router for the table because you will probably graduate to larger projects. I use The smaller laminate trimmers under bench top tables for a lot of the work I do but I have a 2 1/4 hp and a 3 1/14 Hp Porter Cable under the other tables for the heaver work I do.
Not saying you need to get a Porter Cable router but get a bigger router for the table, I think you will find it was a good choice.
MEBCWD is offline
post #4 of 4 (permalink) Old 01-28-2012, 12:07 AM
I have a DW610 and really like it for small bits. I don't use it in my table. I have 2 Hitachi M12Vs for that. Any bit that is recommended for use only on a router table is probably too big to be used with a 610 or 616.
Radial Arm Saw 113.19750 (C) manual + important upgrade note allthunbs Craftsman Manuals 1 01-01-2012 09:29 PM
upgrade my router table satlinkco Table-mounted Routing 4 11-09-2011 07:02 PM
Other (Not Listed) radial arm saw recall upgrade kit manual allthunbs Craftsman Manuals 0 04-19-2011 07:07 PM
Inexpensive Drill Stand Upgrade istracpsboss Tools and Woodworking 13 02-18-2010 02:40 PM
router table upgrade mychef Table-mounted Routing 1 08-08-2009 04:07 AM
