Tolerance!!!! - Router Forums
post #1 of 5 (permalink) Old 01-29-2012, 10:32 PM Thread Starter
paduke's Avatar
Default Tolerance!!!!
Not as in respecting opinions but as in how close is close tolerances
A link by RJM in the thread below shows how to use playing cards to measure height adjustments on a reversible glue joint
http://www.routerforums.com/router-b...ing-miter.html
so I put a deck of cards in the shop and use them frequently. For grins I placed the deck in a squezze clamp an measured the deck thickness divided by #of cards and came up with each card equalling .011 thousands
I checked card against feeler gauge and verified the math so know i have an inexpensive feeler gauge that can measure what I cant see or feel
paduke is offline
post #2 of 5 (permalink) Old 01-30-2012, 12:06 AM
wbh1963's Avatar
Slick stuff Bill! I use all kinds of different 'objects' to measure other things with tactile touch, which in my case is far superior to my eyeballs making out the lines on a ruler. Oddly enough, especially considering my appreciation for poker, using playing cards had simply never occurred to me.
Thanks for the tip!
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #3 of 5 (permalink) Old 01-30-2012, 09:56 AM Thread Starter
paduke's Avatar
Default example
I am building a router fence Playing cards were used to set the height of the sliding whatchacallit. I set the height with 3 cards close to 1/32" above table
paduke is offline
post #4 of 5 (permalink) Old 01-30-2012, 10:26 AM
Hi Bill
May I ask why you want the fence off the table top by 1/32 or so you don't want any space under the fence, it's a good place for the chips to get hung up at and move the stock away from the bit..
Just asking Bill
post #5 of 5 (permalink) Old 01-30-2012, 04:32 PM Thread Starter
paduke's Avatar
Bob
The sub face was slotted prior to assembly. The MDF fence face material was placed at that height and marked for thru bolt location. after being installed it rests perfectly flat on table and slides wonderfully without any bolt snags That 1/32nd was perfect for achieving accurate results
paduke is offline
