Homemade Horizontal/Vertical router - Router Forums
post #1 of 3 (permalink) Old 01-30-2012, 06:35 AM Thread Starter
Default Homemade Horizontal/Vertical router
The hollow split fence moves across just like a table saw fence that can be adjusted for different sized bits with a vaccuum hookup at the far end.U could run a dado cut the length of a 4 x8 sheet if u wanted to.The left side of table is hinged to tilt up to 90 degrees & lock in at any angle.The turnbuckel allows for travel back & forth.The router is hinged which alows it to tilt left or right 45 degrees also has a crank which allows the router to slide up or down.
boozeo is offline
post #2 of 3 (permalink) Old 01-31-2012, 12:50 AM
Welcome to the forum...
Sydney, Australia
jw2170 is offline
post #3 of 3 (permalink) Old 01-31-2012, 01:48 AM
digitless's Avatar
So basically you've made a manual CNC machine?
Even though I don't really understand what you did, it's still pretty cool.
Runs With Scissors
digitless is offline
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
Homemade adjustable router fence. NewMontanaWorkshop Jigs and Fixtures 17 06-13-2012 10:12 AM
Homemade Router Table Insert Question? deck99 Jigs and Fixtures 3 07-03-2006 11:56 PM
