Freud T&G Adjustable Bit for Cabinet Doors - Router Forums
post #1 of 12 (permalink) Old 01-30-2012, 09:21 PM Thread Starter
First Name: Fred
Default Freud T&G Adjustable Bit for Cabinet Doors
Hello All
Yes, I am a newbie to the Router Forums (though I have been lurking for a few months ). I am in the process of making some shaker like doors using Freud's Adjustable T&G bits. I have the set up down to make the T&G for the rails and stiles, now I want to router the frames to allow the use of glass as the panel rather then the standard wood panel normally installed at glue up. Rather then re-invent the wheel I thought I might check here for possible solutions. Any suggestions would be greatly appreciated.
Tall Fred
You are only as Tall as your Dreams......
TallFred is offline
post #2 of 12 (permalink) Old 01-30-2012, 09:53 PM
If you haven't cut the groove for the panel yet you can use a slotting cutter to do it to the size of the glass you choose. Slotting cutters come in many widths.
If the groove is already cut, only 2 choices I can see. One, put a bead of colored silicon in the groove to take up the slack. Two, cut the back of the groove off creating a rabbet and cut a moulding to hold the glass from the backside.
post #3 of 12 (permalink) Old 01-30-2012, 10:11 PM
post #4 of 12 (permalink) Old 01-31-2012, 12:33 AM
Welcome to the forum, Fred.
Sydney, Australia
jw2170 is offline
post #5 of 12 (permalink) Old 01-31-2012, 08:16 AM
thadius856's Avatar
First Name: Thadius
Use the existing groove and hold it in place with glazing tacks?
thadius856 is offline
post #6 of 12 (permalink) Old 01-31-2012, 04:41 PM Thread Starter
First Name: Fred
Thank you all for your help... Will most likely try a rabbet on the existing door on the back side of door and then glass clips to hold glass in.
TallFred is offline
post #7 of 12 (permalink) Old 02-02-2012, 08:01 AM
First Name: Frank
I made 2 doors for a chimney cabinet that sits on top of the vanity in our recent bathroom remodel.
We couldn't find a suitable glass pattern in the ready made shower doors, so we went to a custom shower door manufacturer in our area. We found the glass we liked, had the enclosure made, then ordered the same glass for some shelves, as well as the 2 doors.
I thought that slots cut for the glass would mean completely disassembling the door in the unlikely event that the glass would have to be replaced. So I simply cut a rabbit in the back, and set the glass in with silicone. I made the vanity and upper cabinet out of maple, then painted it all gloss white. (Her choice, not mine)
Using white silicone was a simple solution, and despite how it sounds, it actually looks pretty good.
I guess my suggestion would be something similar, or the glass clips as you mentioned.
Name:	door front.jpg
routafinger is offline
post #8 of 12 (permalink) Old 02-02-2012, 08:56 AM
You do not have to disassemble doors to get glass out. Glass is put in last after door is finished. It sits in a rabbet on the backside like you did. There are several ways to hold glass in. The slot being referred to is probably the 1/8" slot to allow a rubber glass retainer to slip into to hold the glass panel in.
Rubber Glass Retainer 25' Roll-Sommerfeld's Tools For Wood
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #9 of 12 (permalink) Old 02-02-2012, 09:19 AM
Hello All
Tall Fred
Here is a glass panel bit set that should closely match what you have if you can't find it in a Freud set. Use this set to make your glass doors. You can even use these bits to make a divided light door. He has DVD's that show construction of divided light doors. This door here was made using one of his sets.
Shaker Glass Panel Set-Sommerfeld's Tools For Wood
Marc Sommerfeld's New Expanded DVD Collection
Name:	Glass Cabinet Doors 001 Large Web view.jpg
Name:	Glass Door Insulation 002 Large Web view.jpg
Name:	Glass Cabinet Doors 002 Large Web view.jpg
Whittier, CA.
jlord is offline
post #10 of 12 (permalink) Old 02-02-2012, 09:34 AM
Hi Frank
Just one more place to see the great Sommerfeld videos is on the net.
Marc S. is very sharp man and he let this one or two just be so others can see his videos, not all of them are listed on the net, so you must buy them from him and others to get them all..
SALE
When do you tell people about your products, every time you can and it's best if he lets others do it for him..
They are well worth the price of 10.oo ea.
GLASS PANEL DOORS with Marc Sommerfeld part001 plus more
GLASS PANEL DOORS with Marc Sommerfeld part001 - YouTube
GLASS PANEL DOORS with Marc Sommerfeld part002 - YouTube
GLASS PANEL DOORS with Marc Sommerfeld part003 - YouTube
GLASS PANEL DOORS with Marc Sommerfeld part004 - YouTube
~ARCH RAISED PANEL DOOR with Marc Sommerfeld - YouTube
http://www.youtube.com/watch?v=Wx4Zq...eature=related
~Изготовление минифасадов и изделий = ~ Making minifasadov and products ▼
http://www.youtube.com/watch?v=WUpEa..._order&list=UL
Shaker type doors
http://www.youtube.com/watch?v=EqHP7..._order&list=UL
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Adjustable Frame for Mdf Raised Panel Doors jerry433 Jigs and Fixtures 6 10-08-2009 02:22 PM
Adjustable Finger (not Box) joint bits jschaben Router Bits - Types and Usage 8 07-26-2009 10:18 PM
Set up for adjustable finge joint bit confette Starting Off 6 12-31-2008 05:45 PM
