which direction - Router Forums
post #1 of 5 (permalink) Old 01-31-2012, 05:54 PM Thread Starter
gallianp's Avatar
First Name: Paul
Default which direction
Using a table with router - I want to rout out the black circle - completely through the board. The board is 3/4" thick.
Using a pattern for a guide with a bearing bit.
So the question is - after drilling a starting hole (not plunging) which direction should I go CW or CCW
Name:	circle router.jpg
From S.W. Missouri
Near but not too near Springfield
gallianp is offline
post #2 of 5 (permalink) Old 01-31-2012, 06:42 PM
Hi
Black hole = ??
post #3 of 5 (permalink) Old 01-31-2012, 07:24 PM
First Name: Drew
The work would move clockwise around the bit for the bit to pull it against a female pattern.
work ->
v bit ^ work v
< work
That said I'd cut all the way through within 1/8" of the pattern with a sabre saw then clean it up on my router table.
Wood grain in solid lumber is another complication. Since you don't want to route into the grain like this
work ->
\\\\\\\ grain
bit
you'll want to flip the work in the pattern or flip pattern + work and switch to a flush-trim bit where the grain reverses direction so you're running like this
work ->
////// grain
<- bit
parallel to the grain is fine, cross-grain is fine, it's just a problem in between where it starts acting like a feather board pointing in the wrong direction.
Drew Eckhardt is offline
post #4 of 5 (permalink) Old 01-31-2012, 07:37 PM Thread Starter
gallianp's Avatar
First Name: Paul
Clockwise -- thanks!
Bob -- Black-hole -- collapsing Star. not sure where you got a black -hole.
I did draw a black circle after it is cut out it maybe a red hole if I go CCW.
From S.W. Missouri
gallianp is offline
post #5 of 5 (permalink) Old 01-31-2012, 08:09 PM
Hi Paul - don't forget to control that center piece. Once it is cut free from the board the bit is liable to throw it at you.
John Schaben
jschaben is offline
rotation direction of the router bit bobmurphy Sign Making 3 01-24-2012 06:39 AM
Feed Direction, Complicated? kolias Portable Routing 96 06-25-2010 03:46 AM
Feed Direction with hand-held Router bandsaw barry General Routing 3 05-19-2010 03:21 AM
Rotation direction for DeWalt 618 rjchapman New Member Introductions 6 03-21-2010 11:37 PM
Trouble identifying wood gain direction. Router is still my name Tools and Woodworking 2 08-09-2006 04:15 PM
