320-17543 - Router Forums
post #1 of 2 (permalink) Old 02-06-2012, 08:55 AM Thread Starter
Default 320-17543
I have a Craftsman 320-17543. Is there a below table base with a above table key to fit this router (any brand)?
dcherney1 is offline
post #2 of 2 (permalink) Old 02-06-2012, 09:03 AM
Cochese's Avatar
First Name: C
Below table?
I have an table insert plate from Rockler that I drilled a hole to access the adjustment. All you need is a hex key to spin the adjustment. I use a T-handle hex key out of a Harbor Freight set. I want to say it's either 4 or 5mm.
The 144 Workshop - Ambitious but rubbish woodworking
Cochese is offline
Craftsman 17543 Mounting Plate darrink General Routing 8 02-02-2012 08:23 AM
Close out on Craftsman 17543 Marco General Routing 14 03-05-2011 08:19 AM
Craftsman 17543 cmsgtrlt General Routing 3 12-22-2010 11:39 PM
Sears 17543 Plastic Sub Base Plate Problems hungerfo General Routing 8 02-28-2010 08:44 AM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
