I need to upgrade - Router Forums
post #1 of 11 (permalink) Old 02-10-2012, 06:02 PM Thread Starter
Default I need to upgrade
I've had this old metal Craftsman router table for many years. The legs are rusted away to the point that I need to stop using it. So....I need to upgrade to something else. I want to stay with a table top model because of space. I'm not sure if I want to build something or maybe look for something used. I do not want to spend hundreds of dollars for a new unit. If someone can point me to a link of DIY plans or know of someone that might have something to sell please let me know. I'm new to this forum so I will have a good look around here on the forum tonight to try to pick up a few tips.
Thanks,
Tom
tbfoto is offline
post #2 of 11 (permalink) Old 02-10-2012, 09:54 PM
Tom, read the sticky threads; they are packed with good information like this one:
http://www.routerforums.com/table-mo...tml#post127219
post #3 of 11 (permalink) Old 02-11-2012, 12:09 PM Thread Starter
I don't seem to be able to find the Harbor Freight mounting plate on the Harbor Freight website. Does anyone know if it is still available? If not....what is a good low cost alternative?
tbfoto is offline
post #4 of 11 (permalink) Old 02-11-2012, 12:15 PM
Hi Tom
No longer available but check out the link below by Mike
http://www.routerforums.com/table-mo...ase-plate.html
post #5 of 11 (permalink) Old 02-11-2012, 02:56 PM Thread Starter
That seems like a good deal if there are any left. This is why I came to this forum....for info just like this.
tbfoto is offline
post #6 of 11 (permalink) Old 02-11-2012, 04:03 PM Thread Starter
I also would like to know if a piece of countertop can be used as a taple top? I have a section of countertop that was the cut-out for a double sink in a kitchen counter top. It is flat. The wood is MDF. I guess I need to know if this kind of material will warp. The section I have was cut out a couple years ago but still looks pretty straight and flat.
tbfoto is offline
post #7 of 11 (permalink) Old 02-11-2012, 06:48 PM
Tom,
Quite a number of members have used a sink cut out for their first router table.
I would make sure both side are sealed with high pressure laminate to prevent sagging/warping - but thats just me....
Sydney, Australia
jw2170 is offline
post #8 of 11 (permalink) Old 02-11-2012, 07:57 PM Thread Starter
Originally Posted by jw2170 View Post
Tom,
Are you saying that I should use two pieces and glue the MDF sides together, leaving the countertop surface on both the top and bottom? I assume this is to give it more strength and help keep it from warping.
tbfoto is offline
post #9 of 11 (permalink) Old 02-11-2012, 08:13 PM
Tom; what you suggested would work well, but what James was saying was that it's important that both sides of the MDf/plywood be laminated in order that any expansion or contraction is equalized by the laminate on the bottom. Over time the MDF would tend to warp from the pull of the laminate/glue. On countertops it's not as much of an issue as the ctrtop is firmly attached to the base cabinets. I'd go one step further and suggest that the edges should be sealed as well. In your application, warping would be a major issue...but on the other hand, it is a relatively small surface area.
DaninVan is offline
post #10 of 11 (permalink) Old 02-17-2012, 05:50 PM Thread Starter
I just ordered my base plate from Grizzly today. They are out of stock but expect to have them by the end of March. That gives me a few weeks to get a frame made.
tbfoto is offline
Radial Arm Saw 113.19750 (C) manual + important upgrade note allthunbs Craftsman Manuals 1 01-01-2012 08:29 PM
upgrade my router table satlinkco Table-mounted Routing 4 11-09-2011 06:02 PM
Other (Not Listed) radial arm saw recall upgrade kit manual allthunbs Craftsman Manuals 0 04-19-2011 06:07 PM
Inexpensive Drill Stand Upgrade istracpsboss Tools and Woodworking 13 02-18-2010 01:40 PM
router table upgrade mychef Table-mounted Routing 1 08-08-2009 03:07 AM
