Bosch 1617 - Router Forums
post #1 of 2 (permalink) Old 02-15-2012, 10:34 AM Thread Starter
First Name: N/aRon
Default Bosch 1617
I am building drawers for a plunge base for a 1617 that I haven't yet purchased. What is the height of the plunge base ?
The other question I have is about the wrench needed to change bits when the router is in the table. When my router is in the table, the collet at the top position is about even with the top of my plate. I will be lifting my plate to change router bits but am wondering if an offset wrench recommended. What do most use to do this task ?
thanks in advance, ron
impeyan is offline
post #2 of 2 (permalink) Old 02-17-2012, 02:15 AM
First Name: David
Hey ron,
The plunge router base (RA1166) is 9 3/4" fully extended and about 7 3/4" if you lock it in the "depressed" position. These measurements are without the router in the plunge base.
On the second question, I can't really offer any suggestions since I have just got/started using a RA1171 table with the router and use the wrenches that came with my router for bit changing. It's not the most convenient method, but it works and I'm all about keeping tools to a minimum when possible.
As far as getting a plunge router base, I likely wouldn't buy one if I didn't already have one. The kit that included it was cheap enough that I went ahead and got it when I bought my Bosch 1617, but the standard base had a lot more adjustment to it than I initially thought and therefore the plunge base isn't really necessary. I will say this, if you get the plunge router base, consider getting the RA1054.
I bought the router attachment for my Dremel and it came with a guide like this and it's VERY useful for freehand routing with bits that don't have a guide wheel.
The only reason I haven't bought the guide is because I intend on using my router primarily with the table and very little freehand use, so it'd be another tool laying around and in the way. I'll buy it when I need it.
Hope that helps....
amereservant is offline
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1617 with Oak Park table kawisser Table-mounted Routing 25 09-08-2011 06:09 PM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
1617 Bosch and 1/2 & 1/4 collets dtaylor15 General Routing 1 03-10-2006 05:07 PM
