Help needed with a project please - Router Forums
post #1 of 5 (permalink) Old 02-18-2012, 01:01 AM Thread Starter
Question Help needed with a project please
Hi Good Peoples,
I am making a Trivet, (see attachment - metric measurements) and need some advice please.
Cutting the slats/bars are complete, but I don't know the best/easiest way to cut the 1/4" dados in the feet and the end blocks.
I have a Kreg Precision Benchtop Router Table with a Dewalt DW621 Router. Ideally, I would like to use the router as I don't have a dado blade for my table saw.
The problem is how do I make these cuts consistently and accurately? If I have to make a jig, what sort as it only has the one (mitre) slot at the front of the table.
Any ideas please?
TORB is offline
post #2 of 5 (permalink) Old 02-18-2012, 03:37 AM
Hi
I would suggest using the (box spacer jig from OP ) run a wide board over the bit and then cut off some strips to hold the long sticks in place, just like making some box joints so to speak. but not showing the end grain..but use some good hardwood they will want to snap off easy at glue up time.
Oak Park Enterprises Ltd.: Catalogue
Originally Posted by TORB View Post
Hi Good Peoples,
Any ideas please?
post #3 of 5 (permalink) Old 02-18-2012, 08:24 AM
N/A, the feet for your project are easily cut with a box joint jig as BJ mentioned. Add the width of your saw blade X4 to the width of each foot X 5; this is the ideal width to work with. Be sure to use a push block to reduce tear out.
post #4 of 5 (permalink) Old 02-19-2012, 01:20 AM Thread Starter
Thanks to both of you for the help and suggestions. That Oak Park Jig looks great, but as I am in Ozstralia and want to finish the job reasonably soon, buying it was not an option, so I knocked up a similar jig today and it works....... much to my surprise and satisfaction.
TORB is offline
post #5 of 5 (permalink) Old 02-19-2012, 02:28 AM
It just so happens there are several of the Oak Park jigs in Oz; near Perth and near Sydney. I'm glad to hear you made a jig and were able to finish your project... good on ya!
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
A Few Questions about Templates and Tools Needed for project. cuonebay Guide Bushings and Templates 22 10-11-2010 04:49 PM
