Incra upgrade question - Router Forums
post #1 of 10 (permalink) Old 02-20-2012, 08:36 AM Thread Starter
Big Steve's Avatar
First Name: Steve
Default Incra upgrade question
I have a question on whether I should upgrade my Incra Ultra 18" to LS.
The Ultra is about ten years old. It has seen very limited use, but I am ramping up to get back into the shop. I want to work on boxes and other small projects.
I have a new Triton 3 1/4 HP router.
Is it worth it to upgrade to the LS? If yes, 17" or 25"?
Input happily received.
Steve
Richmond, Virginia
Big Steve is offline
post #2 of 10 (permalink) Old 02-20-2012, 08:49 AM
First Name: Gary
They both do the same thing, so why spend the bucks?
gary
Stuck is offline
post #3 of 10 (permalink) Old 02-20-2012, 10:22 AM
mjdorsam's Avatar
First Name: MikeD
Steve:
The primary difference is the LS (Leading Screw) allows microsopic (1/64") fine-tuning for either advanced dovetail work or to micro-adjust a setting. I have the TS-LS with WonderFence setup. While I've use the leading-screw feature in situations where I've needed the micro-adjust, this hasn't been often-enough that I would justify the $180 that would be required to change-out the setup - this is my values stream speaking, and I can't make that comment from your perspective. Also, if I did advanced dovetails, I'd probably go with a Leigh jig, rather than use the Incra - I've been there, and it takes a lot of practice to get proficient with Incra dovetailing.
Regarding the LS17 vs LS25, there are two considerations - the LS25 is $30 more, from Amazon; and the Router Table itself has to be large enough to accommodate the extra spacing (assuming you don't build an aux table to support the Positioner base). From a purely practical view, I'm not sure the extra 8" capacity buys a lot.
I hope this helps.
MikeD
mjdorsam is offline
post #4 of 10 (permalink) Old 02-20-2012, 10:41 AM Thread Starter
Big Steve's Avatar
First Name: Steve
Mike and Gary,
Thanks for the input. Your evaluations match mine, but I am so susceptibleto the "newest advance" argument, especially in something as specialized as the Incra Jigs.
Absent any further input I will probably pass.
Steve
Richmond, Virginia
post #5 of 10 (permalink) Old 02-20-2012, 11:10 AM
First Name: Gary
As you know, the Ultra has the micro adjustment. You might want to upgrade the Ultra to the Wonder Fence. That is what i just did to my Ultra. Incra had a sale on the upgrade, but it ended 2/14/12.
Gary
Stuck is offline
post #6 of 10 (permalink) Old 02-20-2012, 02:08 PM Thread Starter
Big Steve's Avatar
First Name: Steve
I actually have the Wonder Fence with my Ultra Jig as well.
Steve
Richmond, Virginia
post #7 of 10 (permalink) Old 02-20-2012, 03:39 PM
mjdorsam's Avatar
First Name: MikeD
Stuck:
Thanks for the correction - I was not aware the Ultra Fence had the micro-adjust; though, it is a different version than the typical LS.
Steve: if you have the Wonder Fence, then I think you have about as much capability as you'll need.
MikeD
mjdorsam is offline
post #8 of 10 (permalink) Old 02-20-2012, 06:37 PM Thread Starter
Big Steve's Avatar
First Name: Steve
Originally Posted by mjdorsam View Post
Stuck:
MikeD
Thanks Mike
Steve
Richmond, Virginia
post #9 of 10 (permalink) Old 02-20-2012, 11:50 PM
charimon's Avatar
First Name: Craig
Send a message via Yahoo to charimon
I teach the incra system locally and have clients who have the Ultra. To be honest it is more comfortable to use ( I can not explain it but when used side by side for the same task the ultra is often commented on as being easier to use). If you do upgrade i would be interested in buying your old one.
If you eat what you kill. You better HUNT !!!!
charimon is offline
post #10 of 10 (permalink) Old 02-21-2012, 03:19 PM Thread Starter
Big Steve's Avatar
First Name: Steve
Thanks Craig. I think the question is now answered as I will stay with what I have. Where is "locally"? I am in Richmond, VA.
Steve
Richmond, Virginia
Incra Hinge Jig Question Ken Bee Jigs and Fixtures 3 06-01-2011 02:18 PM
Just got an incra positioner an have a question? willydp Jigs and Fixtures 4 01-20-2011 07:34 AM
Incra Magna-Lock plate Question spearthrower Table-mounted Routing 10 05-28-2010 11:59 AM
Incra question. Forum shopping S Bolton Jigs and Fixtures 7 03-18-2010 07:10 PM
