Bosch router base - Router Forums
post #1 of 4 (permalink) Old 02-23-2012, 10:43 PM Thread Starter
First Name: Richard
Default Bosch router base
Anybody use the new Bosch under table base with hex key on top?
Richardvad is offline
post #2 of 4 (permalink) Old 02-24-2012, 02:34 AM
First Name: Larry
I use the RA1165 Base under my table. Once I had the RA1165 Base in hand I realized that it was really just the RA1161 fixed based that came with my with my 1617EVSPK sans the wooden knobs and black subbase. I've no idea if Bosch modified the RA1161 at some point in time, but if bet if you pull the subbase off your RA1161 you will see the opening that accepts the hex key.
LUnger is offline
post #3 of 4 (permalink) Old 02-24-2012, 09:09 AM
Hsobel's Avatar
First Name: Harold
That is exactly what they did. After seeing it I sent mine back in order to use the fixed base I already had. Just take off the baseplate and you're good to go!
Hsobel is offline
post #4 of 4 (permalink) Old 02-24-2012, 09:28 AM
Hi Richard
I don't have the Bosch but MANY of the new routers have the same setup like the Craftsman that have it on all the bases,plunge,D-handle,fix base ,so to say you can use any base for the router table setup with the lift kit built into all of them..
http://www.sears.com/shc/s/p_10153_1...=1330097427553
http://www.sears.com/shc/s/p_10153_1...5&blockType=G5
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Question about new DeWalt DW 611 router LBrandt General Routing 29 09-01-2017 10:55 AM
Bosch Router Table Plate Pattern Rhino Starting Off 8 07-16-2015 11:37 PM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
