Anyone make a T-Track with a keyhole bit? - Router Forums
post #1 of 31 (permalink) Old 02-23-2012, 11:21 PM Thread Starter
First Name: Chris
Default Anyone make a T-Track with a keyhole bit?
I'm thinking about trying to make a T-Track in a 3/4" plywood bench top with a keyhole bit. Has anyone tried this, and if so, how did it work out?
Chris Curl is offline
post #2 of 31 (permalink) Old 02-23-2012, 11:26 PM
Hi Chris - I haven't done it but don't see why it wouldn't work. Only thing I can think of is the larger width may not be as wide as you would like which would mean multiple passes and the slot also correspondingly wider. The "lip" would be fixed by the bit configuration.
John Schaben
jschaben is offline
post #3 of 31 (permalink) Old 02-23-2012, 11:38 PM
Hey Chris; this is obviously a fairly common application as T-slot hardware is available. Here's Lee Valley's latest on-line catalogue supplement.
See pg.11 item F
Lee Valley Tools - Online Catalog
It actually makes sense from the point of consideration of structural integrity, although installation could be a pain in some cases(?)...
DaninVan is offline
post #4 of 31 (permalink) Old 02-23-2012, 11:47 PM Thread Starter
First Name: Chris
Dan, I realize you can buy T-Track. That is not the question. The question is if anytone has made a T-Track in wood with their router and a keyhole router bit, and if so, how did it work out.
post #5 of 31 (permalink) Old 02-24-2012, 02:04 AM
gav
Country: Croatia
First Name: Gavin
I recently used my keyhole bit to put a t slot in a piece of oak. It worked fine.
I have yet to test it's capabilities though.
I'm not sure that doing it in plywood is such a good idea given it's layered structure, there might be a chance that any hardware that's in the slot could catch and individual layer and cause it to lift.
One other tip, run a straight bit first to clear the way, then run the keyhole bit.
gav is offline
post #6 of 31 (permalink) Old 02-24-2012, 03:06 AM
First Name: Larry
I recently snagged the Rockler T Slot bit when it was on sale. I've used it to slot both 3/4" Oak Plywood and MDF ... both are holding up fine so far ... I guess alot depends on how much clamping pressure you need. The Rockler bit requires that you first cut a 3/8" slot. Once you have the 3/8" slot, the Rockler bit cuts a slot 5/8" wide by 1/8" deep slot for the head of the bolt. As John indicated, I think that much will depend on the profile of your key hole bit, and I second Gavin's suggestion to cut a slot with the straight bit first and then use the key hole bit to cut the slot for the head of the bolt ... most likely will require a pass down each side.
LUnger is offline
post #7 of 31 (permalink) Old 02-24-2012, 08:49 AM Thread Starter
First Name: Chris
See pg.11 item F
Sorry Dan. I double checked the page you referred to and saw that you were talking about what I was asking about. Sorry again.
post #8 of 31 (permalink) Old 02-24-2012, 09:12 AM
Hi Chris
I do it all the time but have Not had good luck with plywood (junk wood) the slots look good but don't stand up well and you want the item you put in the slot to move free and easy and the plywood likes to break off easy in the slot and jam up the slot.
post #9 of 31 (permalink) Old 02-24-2012, 10:35 AM
No problem, Chris.
I actually missed the point that you were talking about using the slot without track hardware...bad assumption on my part. I do like Lee Valley's flanged extrusion idea , however (the link I posted previously). That would eliminate Bobj3's really valid concern about T slots.
DaninVan is offline
post #10 of 31 (permalink) Old 02-24-2012, 10:46 AM Thread Starter
First Name: Chris
Hi Chris
bob, do you use the "keyhole" bit, or do you use the bit specifically made for making the t-tracks?
also, what kind of wood do you use? how about pine?
Router Accident - Trying to understand what happened Darryl Shop Safety 170 07-07-2017 06:44 PM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
How to Make a Picture Frame learnexperience Table-mounted Routing 10 09-24-2011 04:48 AM
What diameter bit do you use to make cutouts? Skyglider Router Bits - Types and Usage 6 03-04-2009 11:14 PM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 09:03 PM
