Hitachii MV12 bearings - Router Forums
post #1 of 3 (permalink) Old 02-27-2012, 11:07 AM Thread Starter
Default Hitachii MV12 bearings
I have an old Hitachi 3.5HP M12 table mounted router. Routing panels last night the bearings went out to lunch. So I pulled off the end caps but that as far as I can go. Does anyone here know how to get the bearings out? Looks like a press might be required which I don't have. Service quoted me about $100 to install new ones. At that price I'm looking for a new one. A bit of sticker shock for a new one.
AaronRC4 is offline
post #2 of 3 (permalink) Old 02-29-2012, 03:39 PM
Aaron, we do not have info on this on our forums but I found the process one person used here: Hitachi M12 Bearing Replacement
post #3 of 3 (permalink) Old 03-04-2012, 09:43 AM Thread Starter
Hi Mike, Thanks for your reply. I bought new bearings and put them in. Very easy and I have a new router again. I think router bearings need to be replaced on a regular basis especially for table mounted ones.
Worn bearings sneak up on you . I had long forgot how smooth the router used to be. I probably had a bad bearing for a long time and didn't realize it.
AaronRC4 is offline
Replacement bearings for Bosch 1617EVS mickelsen General Routing 2 04-29-2011 07:28 AM
Babbit bearings Jack Wilson Lobby 3 04-09-2011 09:27 PM
Guide bearings istracpsboss Router Bits - Types and Usage 30 04-25-2010 03:47 PM
How are the bearings in your router mike black General Routing 8 04-12-2010 10:03 PM
