Is a laminated top necessery? - Router Forums
post #1 of 43 (permalink) Old 02-29-2012, 03:25 PM Thread Starter
Country: Norway
First Name: Tommy
Default Is a laminated top necessery?
I made a 2" thick top of birch, which I intend to use as a router top. I might reduce the thickness a bit, but ďt'll at least be 1,5". I planned to use it like that, with no formica, plastic or anything else on top.
Is that a bad idea? I'm concerned that it might warp over time. I thought about routing a couple of dovetail slots across the boards underneath, and glue some hard wood in there, or even a couple of metal bars, to keep it flat.
Any advice is appreciated.
Tommy
tdale is offline
post #2 of 43 (permalink) Old 02-29-2012, 05:19 PM
First Name: Russell
The formica will give you a harder surface and you will not get a wear groove but make sure it is stuck down flat.
The Russell is offline
post #3 of 43 (permalink) Old 02-29-2012, 05:41 PM
Marco's Avatar
I have a birch top that I keep a coat of paste wax on. It works for me but most people use a formica type cover for the top and bottom and a hard wood around the sides.
My top originally had formica on it. I used 3M's Super 77 adhesive on it and if it was out in the sun or got real hot it would peel right off................ so I eventually peeled it off and put on a coat of wax. I figure that when it warps I'll build another.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #4 of 43 (permalink) Old 02-29-2012, 07:07 PM
Jack Wilson's Avatar
First Name: Jack
Originally Posted by Marco View Post
"most people use a formica type cover for the top and bottom"
Right, if you only laminate 1 side, there is a strong potential of that side curling as moisture can access the under side and cause it to swell.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #5 of 43 (permalink) Old 02-29-2012, 07:22 PM
Hi
Has anyone looked under the kitchen /bath room counter tops laminate/formica on one side only and they have water on them all the time.. and they last for years and years.. I have seen some with water marks as big as a bath tub and they still hold fast without any curling..
post #6 of 43 (permalink) Old 02-29-2012, 08:12 PM
Marco's Avatar
Hi
I have Bob and that cheap old particle board that it's stuck to ain't warped one bit. I guess if you store or use your tools in the rain or snow you had better have your wood as close to waterproof as possible and 3 coats of paste wax on your tools.
Marco is offline
post #7 of 43 (permalink) Old 03-01-2012, 05:12 AM
ggom20's Avatar
Country: France
First Name: Gerard
Hi
Hello!
Yes i use it too !
Its awfull, but its using a waterproof glue in case of kitchens and bathrooms
the aglomerate is green signaling it's water resistance.
In case of wood I' s quite different , the paint or waterproofing has to be
applied on every side.Seen a nice sample of bending large plywood just painted one
side , for use as support to an art painting live- event last year.
After 1 year, its all bended!
Told them to paint white both side , they did not care .
Regards
ggom20 is offline
post #8 of 43 (permalink) Old 03-01-2012, 06:35 PM
First Name: Jack
Hi
Bob, now don't go giving me a hard time! I have laid plywood in the grass for a few hours and had it bow signifigantly. So there you go!
Jack
post #9 of 43 (permalink) Old 03-01-2012, 06:50 PM
Hi Jack
hahahahahaha I'm not Jack,,, I have seen it used on the job sites for walk ways in the mud/snow and you are right it will bow in a heart beat..but then many will pull it up and put it on the floor or the roof for the sub floors the norm ..at 30.oo bucks each now days they don't waste it now days.. it will go flat one more time.
Once used in the WW11 for PT boats by the tons because they could get it wet and it would bend right around the shape of the boat ( PT 109 plywood boot )
http://www.google.com/imgres?imgurl=...QEwAw&dur=2241
post #10 of 43 (permalink) Old 03-01-2012, 08:02 PM
Marco's Avatar
Pop the bands on a new bundle of flat plywood and take a sheet off. If you don't use it that day it will be ready for the PT 109. No fun especially if it is tounge and groove.
Marco is offline
Work bench top hdusch Project Plans and How To 5 04-05-2015 03:09 PM
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
What type of plastic for a laminated table top? guitardemon Table-mounted Routing 10 03-19-2012 09:09 AM
Need Help Modifying Laminated Top DGouldie Table-mounted Routing 11 03-08-2012 11:38 PM
How to best attach router table top to cabinet? xvimbi Table-mounted Routing 3 05-28-2010 07:30 AM
