Trying to learn how to cut mortise / tendon with a router - Router Forums
post #1 of 10 (permalink) Old 02-29-2012, 03:26 PM Thread Starter
Default Trying to learn how to cut mortise / tendon with a router
Hello. I'm fairly new to woodworking, however, I do have several tools.(Planer,table saw, router w/table, drill press and band sander). I am trying to learn how to cut mortise / tendon with a router. How do u set up table? Jig? Looking forward to lots of help..Thx.
Retiredman is offline
post #2 of 10 (permalink) Old 02-29-2012, 03:52 PM
First Name: Jack
You never, ever want to cut a tendon with a router. Or with anything for that matter.
Tenons are another thing.
I use my table saw to cut them. I have seen some very cool set ups using a router mounted horizontally though.
barking spider is offline
post #3 of 10 (permalink) Old 02-29-2012, 05:46 PM
The Warthog's Avatar
First Name: Roger
Some people say "tenon", I say "tendon."
--Captain Eddie
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #4 of 10 (permalink) Old 02-29-2012, 06:31 PM
First Name: Jack
For that matter, my Mother used to say....
Hawaiya for Hawaii
worsh for wash
and Baskin Robinson for the ice cream place.
If Captain Eddie said he just cut a tendon, how would you know what to say? Good job? or I hope you get out of surgery soon!
post #5 of 10 (permalink) Old 02-29-2012, 06:46 PM
Honored Member
First Name: pat
Some tips on router morticing.
Quillman is offline
post #6 of 10 (permalink) Old 02-29-2012, 11:15 PM
First Name: Jack
woodgears.ca has a lot of jigs and plans for woodworking.
post #7 of 10 (permalink) Old 02-29-2012, 11:24 PM
First Name: Brett
I almost cut a tendon, ok just my fingertips, on a jointer working in a cabinet shop, not a good feeling. But I'm glad this was asked, looking for the same answer.
bclarknc is offline
post #8 of 10 (permalink) Old 03-01-2012, 09:14 AM
First Name: Roger
I have had a couple of router books that can be bought at places like HD, all of which have sections on different ways of mortising. The one that's lying on my floor right now is the Complete Illustrated Guide to Routers, by Lonnie Bird.
Cheers,
Roger
post #9 of 10 (permalink) Old 03-01-2012, 09:29 AM
Hi
Many,many ways to get the job done But the best one I have found is the floating type, it's so quick and easy and ,no guess work needed..
JessEm Zip Slot Mortise Mill - YouTube
post #10 of 10 (permalink) Old 03-01-2012, 12:38 PM
OPG3's Avatar
First Name: Otis
Tendons & ligaments are body parts critical to movement and strength.
Tenons are wooden "rectangular dowels", of which there are a couple of types: (1) loose (a.k.a. "floating" as BJ mentioned above) tenons and (2) integral tenons. For a single loose tenon connection there are 3- pieces of wood (typically). For an integral tenon joint there are 2- pieces of wood, which can be thought of as male and female parts. There are advantages to either methodology - usually it is maker's preference.
Personally, I use a router to make mortises and I use a table saw to make tenons. If I am making integral tenons - I use a tenoning jig - which is a purpose-built table saw sled. If I am making loose tenons - I use the table saw for tenon width and thickness and I use a miter saw to cut the length (cut the length last). Tenons should be slightly shorter than the mortise depth. In a majority of cases, it is easier to make the mortise first - followed by the tenon being made. If you are mortise cutting the end grain of wood, be very careful as that is the hardest surface of a board to penetrate with your router bit. BE SAFE!
OPG3
Tweak everything!
OPG3 is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Table Router Mortise rhaber45 Table-mounted Routing 6 01-01-2011 02:36 AM
shiis allthunbs Jigs and Fixtures 25 02-24-2010 02:24 PM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
