Speed controller for PC 7518 - Router Forums
post #1 of 5 (permalink) Old 03-11-2012, 11:03 AM Thread Starter
Default Speed controller for PC 7518
The speed controller on my Porter Cable 7518 table mounted router died and the replacement part is $120. I by-passed the speed controller so now the router works but only at full speed. I am considering buying a router speed controller for about $40 but I've read that you can't use them with variable speed and soft start routers. My router is no longer variable speed, but I don't know if the soft start function will render the speed controller useless. Has anyone tried this and did it work?
Sundlof is offline
post #2 of 5 (permalink) Old 03-11-2012, 11:25 AM
HI
I use one on a PC7538 and it works fine,once you by pass the device you no longer have the soft start but with the speed control box it's almost a soft start device.
post #3 of 5 (permalink) Old 03-11-2012, 02:54 PM
Ken Bee's Avatar
First Name: Ken
I had the same thing happen to my PC 892 and I did buy a speed controller at Harbor Freight for less than $20.00 and solved the dead router problem efficiently. Mine makes the perfect table router now that I can adjust the height, lock/unlock, change bits and control the speed all above the table.
As bobj3 said, the soft start function is also rendered inoperative when the speed control goes south. If you wired it correctly when you turn the router on it should have the tendency to almost jump out of your hand due to the torque. The first time I started mine it jumped off the workbench because I forgot it was on when I plugged it in. I have always wondered what the importance of soft start is to begin with because my router is at full speed before engaging what I am routing anyhow.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #4 of 5 (permalink) Old 03-12-2012, 08:05 AM Thread Starter
Thanks! That answer's my question.
Sundlof is offline
post #5 of 5 (permalink) Old 03-12-2012, 08:18 AM Thread Starter
Thanks! I'll be placing an order to Harbor Freight. I assumed that the variable speed control also controlled the soft start function, but I noticed that the PC 7519 which is the same motor as the PC 7518 but without variable speed control, also has the soft start feature, hence my question.
Sundlof is offline
PC 5182 Need help making variable speed work lorencharter General Routing 4 11-11-2011 10:05 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 05:10 PM
"What is it?" #138 reible What is it? 13 10-26-2009 10:07 AM
adding a speed controller to a single speed router Sawatzky Table-mounted Routing 5 01-24-2009 09:49 AM
Remote PC 7518 speed control mntbighker Table-mounted Routing 5 01-02-2008 11:43 PM
