Newbie Questions - Router Forums
post #1 of 11 (permalink) Old 03-20-2012, 10:25 PM Thread Starter
First Name: mark
Default Newbie Questions
Hi everyone.
I am new to using a router. I picked up my first router table from home depot, but i am considering not opening and returing for a better router. I picked up a ryobi routing table that comes with a 1.5hp router. I have had good results with previous ryobi products, but this one seems to get very bad reviews. Please let me know what you all think.
I am going to be using this mainly for routing plexiglass, and in the future i would like to make new raised panel cabinet doors to reface my kitchen. Any ideas, opinions or suggestions would be great. Thanks!
black3000gt is offline
post #2 of 11 (permalink) Old 03-21-2012, 07:04 AM
First Name: Keith
When you are looking at tools your budgets rules what you can buy.The problem with the big box stores is the some of the tools they sell are not the best quality.My opinion is buy what will last.
Woodshaper67 is offline
post #3 of 11 (permalink) Old 03-21-2012, 07:55 AM
N'awlins77's Avatar
First Name: Lee
I'm sure you will hear from more true "experts", then I, but from what I've gathered from info here, you will want a more powerful router then 1.5 horses, for when you get into building your raised panel doors. Those bits cut a large surface area.
N'awlins77 is offline
post #4 of 11 (permalink) Old 03-21-2012, 08:59 AM
First Name: Bob
Hello and Welcome
I concur 1 1/2 HP will be to small for what raised panel doors.
Desertcarver is offline
post #5 of 11 (permalink) Old 03-21-2012, 09:20 AM
Big Steve's Avatar
First Name: Steve
Yeah, two thoughts:
  • For raised panels you will want more powerful router. Many will suggest >3 HP, but at least >2HP
  • Good suggestion to buy the best tool you can afford. Buyers remorse sets in quickly (as you saw last night!)
Steve
Richmond, Virginia
Big Steve is offline
post #6 of 11 (permalink) Old 03-21-2012, 10:26 AM Thread Starter
First Name: mark
I have not yet opened the router table. It is sitting down in it's box still sealed. Money isn't that big an issue, i just want to make sure i am not getting more than i need. My main use for the router will be cutting thin plexiglass, 1/4" to 1/8".
I feel for the type of work i will be doing, a router table is the way to go. I guess i could make my own as i just finshed my workbench, well almost. Just waiting for the glue to dry on the hardboard.
I feel i have 2 options.
1) Make my own router table, get a better router.
2) Buy Ryobi's advanced routing table and get a better router.
Option 1 would be a good deal cheaper, build a table should only take a few hours. The other issue is i have VERY limited space so I am trying to stay away from permanent fixtures. Thanks again for all the help!
post #7 of 11 (permalink) Old 03-21-2012, 11:04 AM
bcfunburst's Avatar
First Name: Reg
Default What to Buy
Originally Posted by black3000gt View Post
Hi everyone.
Agreed! Buy the best NOW. No regrets later. For raised panels you will need at least 2 1/4 hp router with 1/2 inch chuck capacity. Craftsman has a good router of that size for very reasonable price, USA. Build your own table with a good quality router plate. (many available) If you are like most of us, you have lots of older scrap wood in stock for building a table, especially if it's not to be permanent. And good luck with whatever you decide. Let us know how it goes, please.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #8 of 11 (permalink) Old 03-21-2012, 11:51 AM
Hi Mark
Your 1 1/2HP router will do the job having a bigger router is nice but not a must have item, the Vert. router bits will do just fine and yes you can use them on a standard router table..(see myloads for a quick fixture you can use on your router table) the real plus they are cheaper and a lot safer to use and take less power to spin..most just make cabinet doors now and than ,real no need to put out a ton of money for the bits..
MLCS Raised Panel Carbide Tipped Router Bits 2
post #9 of 11 (permalink) Old 03-21-2012, 01:33 PM
First Name: Steve
Hi Mark -you mentioned that you will be working with plexiglass but you didn't say if you have experience with it in the past. Especially watch RPMs and heat buildup. Also chip out can be a problem (unless the edges will be covered w/ moulding or something). There are web tutorials that will be beneficial to read.
Steve B. is offline
post #10 of 11 (permalink) Old 03-21-2012, 03:24 PM
First Name: Drew
I bought a top/plate/fence package (Rockler 32 x 24") and put folding legs on it. Works great outside making sawdust and stored inside my 6x14' shed where it doesn't take up much space. I suggest you make or buy a top and do the same.
Drew Eckhardt is offline
slot cutter newbie questions turbo6justin Table-mounted Routing 16 03-27-2014 08:33 PM
Rob- newbie with questions rpto New Member Introductions 9 12-21-2010 10:02 PM
Hello All & Some Newbie Questions! RBM New Member Introductions 3 08-03-2009 01:48 AM
newbie with gratitude and questions pc7007 Table-mounted Routing 8 03-09-2009 02:15 PM
Newbie Questions mikey_sl General Routing 6 09-10-2005 01:28 PM
