king routers - Router Forums
post #1 of 6 (permalink) Old 03-24-2012, 12:31 PM Thread Starter
First Name: steve
Default king routers
hi :
i purchased a new king router and a router table to get started wood working. im havin some problems mounting the router. first should a plunge router be mounted in a table. how do i get the screw sizes and what size holes to drill. as a journeyman carpenter i have no problems centering the router, etc, however are there any little tricks that could help me out. i've check the router and the router table manuals and it gets little or no info on the topic.
thanx
stevesheppard is offline
post #2 of 6 (permalink) Old 03-24-2012, 11:03 PM
Welcome to the router forum.
Thank you for joining us, Steve.
There is no reason why a plunge router cannot be mounted in a table. In fact many members prefer to use a plunge router with the springs removed.
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 03-27-2012, 06:21 AM Thread Starter
First Name: steve
thanx for tip. i tried it... works good. however im using frued bits and with 3/4the shaft in the collet they barely extend over the surface of the table. very little wiggle room fior adjustment. any suggestions
post #4 of 6 (permalink) Old 03-27-2012, 08:30 AM
Steve, did you remove the sub base plate when you installed your router to the mounting plate?
post #5 of 6 (permalink) Old 04-02-2012, 06:37 PM Thread Starter
First Name: steve
ya for sure. however i was bottomin out the bit and then haulin it out a 1/16th. that didnt give me enough extention over the table top. i checked with frued canada. and they told me as long as 75percent of the bit shaft was in the collet i would be fine. it worked fine now. thanx
steve
post #6 of 6 (permalink) Old 04-02-2012, 10:45 PM
mjdorsam's Avatar
First Name: MikeD
You may want to place a rubber grommet at the base of the collect (tipping my hat to Marc Sommerfeld, and you can by some from his online store). In this manner you can automatically set a consistent shank depth. I've used this for years on all of my routers.
MikeD
mjdorsam is offline
Things You Need To Know About Woodworking Routers learnexperience General Routing 11 10-16-2011 04:55 PM
New Craftsman Routers foleylink General Routing 2 11-10-2007 11:48 PM
Freud routers and tables cabinetsetc General Routing 6 11-06-2005 05:06 PM
