Bosch RA1171 - Router Forums
post #1 of 5 (permalink) Old 03-30-2012, 11:02 AM Thread Starter
Default Bosch RA1171
Hi There,
I just bought my first router table to cut rails and stiles. One thing I've noticed over the past few days is that the little plastic plates around the router bit sit a little below the surface of the table. When routing small pieces or short rails this causes varying thicknesses in the rail, tapered.
Any advice?
Take it back?
Buy a phenolic plate?
Tune the plastic plate with masking tape?
Thanks,
Gil
gil_mil is offline
post #2 of 5 (permalink) Old 03-30-2012, 12:08 PM
First Name: RAD
Would definitely tune it up with spacer of some sort. If tape will do it great.
BigRad1 is offline
post #3 of 5 (permalink) Old 03-30-2012, 02:50 PM
This table wearing either the Bosch or Craftsman name is a good choice. Small enough to be easily portable yet big enough to handle most jobs. Shimming the spacer plates is a good idea. Do they all fit the same or are only some of the plates sitting shallow?
post #4 of 5 (permalink) Old 03-30-2012, 07:12 PM Thread Starter
I only tried one. I shimmed it with 5 layers of blue masking tape. Now it's working as expected. It's a great little table for my tiny shop.
-Gil
gil_mil is offline
post #5 of 5 (permalink) Old 03-31-2012, 07:59 PM
First Name: Bobby
I have the 1181A and mine works fine, both have same plates, I would take it back and exchange it. The only other thing I would say is try adjusting the plate the router mounts too with the allen heads, I had to play with mine a little to get it right
stang8689 is offline
Bosch RA1171 or RA1181 JayL517 Table-mounted Routing 9 04-21-2009 07:42 AM
Bosch RA1171 insert plate PIglet Table-mounted Routing 4 11-17-2008 04:58 AM
Freud 2200E and Bosch RA1171 Table 1973vw Table-mounted Routing 7 01-02-2008 04:45 AM
Will Bosch RA1171 table handle 3 1/2 HP router? LBrandt Table-mounted Routing 3 03-25-2007 10:05 PM
Bosch RA1171 woodendigits Table-mounted Routing 5 06-08-2006 04:06 PM
