Router bit keeps rising - Router Forums
post #1 of 14 (permalink) Old 03-31-2012, 02:20 PM Thread Starter
First Name: Sal
Default Router bit keeps rising
why does my router bit keep rising when I make a straight on my table?
foothills is offline
post #2 of 14 (permalink) Old 03-31-2012, 06:33 PM
Hi Sal - Welcome to the forum
Just a tad bit more information would be helpful... router brand, bit configuration, shank size, type of wood, bit brand, general condition of everything..
John Schaben
jschaben is offline
post #3 of 14 (permalink) Old 03-31-2012, 07:27 PM
Honored Member
First Name: pat
Spiral bit?
Quillman is offline
post #4 of 14 (permalink) Old 03-31-2012, 08:12 PM
Welcome to the router forum.
Thank you for joining us, Sal.
Sydney, Australia
jw2170 is offline
post #5 of 14 (permalink) Old 03-31-2012, 08:15 PM
First Name: Frank
When you dropped the bit into the router, did you raise it up about 1/8" so that it is not resting metal-on-metal fully seated into the collet? Sometimes, if the bit is fully seated to the bottom of the collet, the collet can't be tightened as much as it should, allowing the bit to rise during the cut.
Putter is offline
post #6 of 14 (permalink) Old 04-01-2012, 11:21 AM Thread Starter
First Name: Sal
It's a Ryobi router and table, brand new, 1/4" collet, bit is a straight cut 3/4" x 1" deep and I'm cutting down the of 18" redwood 4" x 4".
post #7 of 14 (permalink) Old 04-01-2012, 11:22 AM Thread Starter
First Name: Sal
Yes I did
post #8 of 14 (permalink) Old 04-01-2012, 11:24 AM Thread Starter
First Name: Sal
My pleasure, I hope to learn a lot here.
post #9 of 14 (permalink) Old 04-01-2012, 11:32 AM
Will try to make a couple of guesses here. First, are you trying to do a full one inch deep 3/4" wide cut??? That is waaay to much for a small router and 1/4" shank bit to handle without some kind of issue. 1/4" depth of cut for that setup should be absolute maximum, some would say you're pushing it at that.
Second, Frank had a good point about the bit being seated to deeply in the collet. You want it well into the collet but not bottomed out. Dropping it in and then pulling it back up about 1/8" is a fairly good rule of thumb.
Third, the obvious, are you sure it was tight?
Keep us posted
John Schaben
jschaben is offline
post #10 of 14 (permalink) Old 04-01-2012, 12:07 PM
Gene Howe's Avatar
First Name: Gene
The same thing happened to me, but the bit was in an 1/4" adapter. A 1/4 collet fixed it. But, you say you are using a 1/4" collet already. I can only suggest getting it as tight as you can. and, maybe, roughing up the shank with some sand paper.
Gene Howe
Snowflake, AZ
Gene Howe is online now
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 09:46 AM
