burn marks - Router Forums
post #1 of 6 (permalink) Old 04-06-2012, 07:46 AM Thread Starter
Default burn marks
Hi;
when I'm using a round over bit on my table and rounding edges on long boards when i have to move my hands to regrip the board to continue i get little burn marks at the spot where i stopped momentarily to move my hands, any suggestions to correct this?
curly1 is offline
post #2 of 6 (permalink) Old 04-06-2012, 09:20 AM
walowan's Avatar
First Name: Michael
move the router away from the board when not moving along the edge, restart a little behind where you left off....
walowan is offline
post #3 of 6 (permalink) Old 04-06-2012, 10:12 AM
oliverc612's Avatar
First Name: Oliver
Smile Turn down the router speed
If you have an adjustable speed router motor, try turning down the speed. I had some issues routing some maple recently and found that if I turned down the speed, it did not burn as much.
Oliver
Loomis, CA
Hobby Woodworker
oliverc612 is offline
post #4 of 6 (permalink) Old 04-06-2012, 10:22 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
What Michael said.
Harry
harrysin is offline
post #5 of 6 (permalink) Old 04-13-2012, 09:06 PM
First Name: Keith
Agree with turning down router speed. Cherry burns pretty easy too. Also don't route to the the full depth. Make the final pass so that it takes off very small amount of material.
radar57 is offline
post #6 of 6 (permalink) Old 04-13-2012, 09:21 PM
Originally Posted by curly1 View Post
Hi;
Hi Dan - I also agree with turning down the speed a little, also make sure the bit is clean. A dirty bit will run hotter.
John Schaben
jschaben is offline
Burn marks on Cherry end grain RJH Wood Species 2 03-15-2011 03:06 AM
Burn marks rosq General Routing 5 10-31-2007 07:03 PM
erasing pencil marks on projects Joe Mulherin Tools and Woodworking 1 08-20-2006 01:54 PM
Burn Marks TOMW. Table-mounted Routing 3 10-02-2005 02:55 AM
