Bosch 1617 EVS mounting plate - Router Forums
post #1 of 2 (permalink) Old 04-10-2012, 04:45 AM Thread Starter
First Name: Ted
Default Bosch 1617 EVS mounting plate
Hi, I just bought a Bosch 1617EVS with the RA1165 router table mount. I have a Craftsman router table - cabinet type. The mounting plate is 7" X 8". I have mounted a Craftsman and a Skill router with no issues. The Bosch mounting holes do not match up. I can't afford a new table right now. Any suggestions or known adapter plates that would help?
ttromler
Scroll Sawing in Omaha
ttromler is offline
post #2 of 2 (permalink) Old 04-10-2012, 11:15 AM
MikeMa's Avatar
Hi Ted,
Probably your best bet is to drill new holes in the mounting plate for the table that will line up with the screw holes for the bosch.
MikeMa is offline
Bosch EVS 1617 Adaptor to use PC accessories? kessler craftsman Guide Bushings and Templates 8 05-11-2011 09:35 PM
New member question about trouble with a Bosch 1617 EVS SD tinkerer New Member Introductions 5 09-26-2009 05:07 PM
Bosch 1617 EVS speed control problem pkunze New Member Introductions 4 07-11-2009 09:30 AM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
