raised panel - Router Forums
post #1 of 5 (permalink) Old 04-19-2012, 07:30 PM Thread Starter
First Name: Milo in Texas
Default raised panel
I am considering purchasing a Freud raised panel and stile/rail router bit set. Theis will be used on a Bosch 2.25 HP router and table setup.
I like the ogee raise panel Quadracut but am debating the plain versus back-cutter bit. What do you experienced craftsmen recommend?
Thanks,
Milo
gsmilo52 is offline
post #2 of 5 (permalink) Old 04-19-2012, 07:49 PM
I prefer the back cutter. It's saves extra time & extra setup.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 5 (permalink) Old 04-19-2012, 07:51 PM
Back cutters make the milling process a little different.
If you go with several passes to the final cut, the fence is progressively moved into the bearing (rub collar) and the backcutter bit is set to height from the get go.
With out the backcutter, you can progressively raise the bit to final cut and the fence is set to position from the get go.
No problem with either way and most times the back cutter allows for a fixed thickness of edge to insert into rail and stile. The "plain" cutter allows for custom edge thickness if needed.
I usually end up backcutting regardless, unless I'm using thinner panel stock.
TomE is offline
post #4 of 5 (permalink) Old 04-19-2012, 07:55 PM
You can also fine tune the thickness of the tenon with a back cutter. Most come with shims for this. If you find that you do not need the back cutter you can take the cutter off.
Whittier, CA.
jlord is offline
post #5 of 5 (permalink) Old 04-19-2012, 08:12 PM
Good point James,
I've only got a few backcutter sets and use those profiles as is. Most of my profiles don't have the backcutters and need a separate cut to thickness.
TomE is offline
How to Make a Raised Panel Door learnexperience General Routing 2 09-06-2011 08:39 PM
1/2" Stock for Raised Panel rdlorenzo Router Bits - Types and Usage 5 11-19-2010 09:00 AM
help with raised panel bits ccmnova Router Bits - Types and Usage 28 08-19-2010 09:11 PM
Wainscoting Raised Panel jerry45 New Member Introductions 3 08-11-2009 08:56 PM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
