Router plates bigger than 11 3/4 x 9 1/4 - Router Forums
post #1 of 8 (permalink) Old 04-28-2012, 05:03 PM Thread Starter
Default Router plates bigger than 11 3/4 x 9 1/4
I was working on routing out the top on my new router table, and had an issue with the bearing on my template guide. Long story short the routed out area does not look nice... Are there any router plates bigger then 11 3/4 x 9 1/4? If not is there any way of saving my table top?
guitardemon is offline
post #2 of 8 (permalink) Old 04-28-2012, 09:51 PM
Most of the commercial plates are either 9x12 or 9 1/4 x11 3/4. There are a few odd ones around but most smaller, I think. Post a pic of what you have and maybe we can can come up with some suggestions. Another option would be to get a blank aluminum or lexan piece of stock and make your own although making inserts can be a bit problematic.
John Schaben
jschaben is offline
post #3 of 8 (permalink) Old 04-29-2012, 12:14 AM
What material is your top? You can always cut out the damaged area and make an inlay to fill in the gap. Let me say this is a router table... pretty is not important, functional is.
post #4 of 8 (permalink) Old 04-29-2012, 07:08 AM
First Name: Thrifty
How deep did you cut? If it's 3/8" deep.........get a piece of lexan/acrylic and make a new plate. If you want to be really frugal, a piece of 1/4" plywood laminated with formica top and bottom is 0.34". With a 1/32" shim and piece of paper or two, you're close enough.
Thrifty Tool Guy is offline
post #5 of 8 (permalink) Old 04-29-2012, 09:54 AM
First Name: Ed
Screw pieces of steel angle on all four sides of the hole at a height that holds the router plate level with the table top. Remove the plate, coat it with vaseline or grease, and then use glass bedding compound (used for guns and available at Brownells.com) to fill in any gaps and help hold the metal in place. Place the router plate in the top in while the compound is soft and make sure that all gaps are over full. After the compound dries; remove the router plate and wet sand the compound to dead level with the top surface.
eaeopc is offline
post #6 of 8 (permalink) Old 04-29-2012, 10:33 AM
TWheels's Avatar
If you have the right router you might be able to get one of the remaining stockof 11 x 11 in base plate at Oak-Park Oak Park Enterprises Ltd.: Catalogue
Also Lee Valley sells lexan (polycarbonate) in two thickenss, 1/4 in aqnd 3/8 in at
Polycarbonate Sheets - Lee Valley Tools and these can be routed in much the same way as wood so you can make whatever size, shape and opening you want.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 8 (permalink) Old 04-29-2012, 03:54 PM
First Name: Bob
I've made mine out of 12mm (1/2") MDF. Works just fine. In fact I made several, with different size openings. As long as it is supported on all 4 sides it will not warp.
heromed is offline
post #8 of 8 (permalink) Old 06-04-2012, 12:11 AM
First Name: david
I agree w/ Mike get some straight wood or take the straight side from MDF, Plywood which has been cut off and use it as your straight edge to get every thing squared up then add in a filler piece back into the table.
Just remember you will need to square up the corners prior to adding in the filler pieces.
Dave
david cooksey is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
1/4 Router Extension llcooljr General Routing 5 03-16-2011 07:12 PM
