Horizontal slot mortising: Variable speed important? - Router Forums
post #1 of 4 (permalink) Old 05-07-2012, 10:43 PM Thread Starter
TanOak's Avatar
Default Horizontal slot mortising: Variable speed important?
Hello All:
I have been reworking my slot mortiser with a new vertical travel mechanism and I am deciding which of my routers to install. I have two Bosch 1617 routers and one of them is variable speed. How important is it to have variable speed in this application? Also, if its important, why? If it helps, I usually use spiral end mills (dirt cheap on ebay) as cutters and also have a few true router bits. Range of sizes is 1/4 to 1/2". If the fixed speed is fine that would free up the VS for other tasks. Yes I could switch the routers out from time to time but its not very convenient with the way it all goes together and I would prefer to just set one in and leave it.
Thanks,
Jim
TanOak is offline
post #2 of 4 (permalink) Old 05-07-2012, 11:30 PM
wbh1963's Avatar
Changing the RPM is just one of several ways to 'slow down' (or speed up!) a cut.
Depth of cut can be adjusted, rate of feed, and in some situations, a smaller or larger diameter cutter can be used to try and fix whatever isn't right about the cut.
Sometimes RPM is exactly what needs to be adjusted and sometimes it doesn't have anything to do with it.
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #3 of 4 (permalink) Old 05-08-2012, 06:53 AM
kp91's Avatar
First Name: Doug
I agree, Usually if you are mortising, you're not using a large diameter bit, so bit speed isn't a huge concern. Find a speed that seems to work and leave it there, take several light passes and you'll be OK.
Nice looking machine!
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 4 (permalink) Old 05-08-2012, 08:10 PM
Router speed is probably a lot less important than feed speed. As Doug said, the bits are relatively small so full speed shouldn't be a problem.
Variable Speed vs. Fixed Speed Phillip K General Routing 26 10-23-2013 10:38 AM
PC 5182 Need help making variable speed work lorencharter General Routing 4 11-11-2011 09:05 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Is variable speed important for Colt? crquack General Routing 4 12-28-2010 05:05 PM
Is variable speed important? S Bolton General Routing 9 09-29-2007 12:37 AM
