Anyone use the Kreg insert? - Router Forums
post #1 of 7 (permalink) Old 05-23-2012, 09:01 AM Thread Starter
First Name: Roger
Default Anyone use the Kreg insert?
I am trying to find the outside diameter of the replacement insert ring on the Kreg plate. I am trying out an idea which would involve those rings but, the measurements can be found nowhere.
Any help would be greatly appreciated.
Do as you always do,,, Get what you always get
rcp612 is offline
post #2 of 7 (permalink) Old 06-03-2012, 11:43 PM
First Name: david
Default Kreg Blue Insert Plate
Hole Dia. is 1 31/32"
david cooksey is offline
post #3 of 7 (permalink) Old 06-04-2012, 09:19 AM Thread Starter
First Name: Roger
Thank you David.
But, I really meant the outside of the insert, or, the hole size in the plate.
rcp612 is offline
post #4 of 7 (permalink) Old 06-16-2012, 03:03 AM
First Name: Anthony
Default Kreg Insert Plate Reducing Ring Diameter
4 1/4" If I understood you correctly see picture. There is a 5 16th's of an inch lip. Or Rabbet. Including the Rabbet 3 5/8ths" Give or take a 32nd / 16th of an " Eyeballed it
Hope this helps.
amassey08873 is offline
post #5 of 7 (permalink) Old 06-16-2012, 03:06 AM
First Name: Anthony
Failed to get these in with the last post. >>><<<
post #6 of 7 (permalink) Old 06-16-2012, 06:45 AM Thread Starter
First Name: Roger
Thank you very much Anthony.
I couldn't get that measurement from Kreg for some unknown reason but, since that time, I've discovered that they do not sell the rings separately anyway.
Thanks again.
rcp612 is offline
post #7 of 7 (permalink) Old 06-18-2012, 09:51 AM
First Name: Anthony
No problem at all, glad I could help for a change :-).
Does it have to be Kregs reduction rings, or would another company's help. Cause I know I've seen a few who sell them?
Router Table Plate Leveling Adjustment oldhippie1951 Table-mounted Routing 6 01-04-2011 07:04 PM
Insert plates - again! crquack Table-mounted Routing 5 12-17-2009 03:19 PM
Kreg precision router table my *** AnthonyBklyn General Routing 4 06-08-2009 07:56 PM
ZC Insert kolias Tools and Woodworking 7 01-01-2009 10:17 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
