variable speed control - Router Forums
post #1 of 10 (permalink) Old 05-23-2012, 05:40 PM Thread Starter
Default variable speed control
Hi folks.
Does anyone know where I can get a variable speed controller for a router? I have 2 fixed speed routers and for the type of work I have done, fixed speed routers have worked fine. Now I want to use a large router bit and the speed of my routers is way too fast and I need to slow the routers down for safety reasons.
I can get a controller kit that I have to put together my self but I would then need to buy a soldering iron to put it together, and maybe other bits and pieces too, which would make the whole thing too expensive.
Anyone know where I can get a ready assembled speed controller for a router?
smart alex is offline
post #2 of 10 (permalink) Old 05-23-2012, 05:55 PM
neiltsubota's Avatar
First Name: Neil
Did you try Woodcraft.com ?
Here is the link:
Buy Router Speed Control at Woodcraft
neiltsubota is offline
post #3 of 10 (permalink) Old 05-23-2012, 06:42 PM Thread Starter
Default Oooops
I forgot to mention that the controller needs to be for 240 volt routers.
Thanks neiltsubota for your quick reply, sorry I was not more specific.
Not as smart as I say I am.
post #4 of 10 (permalink) Old 05-23-2012, 09:55 PM
NEW Router Variable Speed Control Box 220-240 VOLT UK EUROPEAN VOLTAGE NEW | eBay
NEW 220--240 VOLT ROUTER SPEED CONTROL BOX
Great for routing tough woods, plastics and even aluminum
Plug your router into this control unit & you instantly have a variable speed tool!
Works with any universal AC/CD brush type motor
8 AMPS & under
Input Voltage 220-240 volt capacity
Features: Variable speed or full run
Dim: 4-3/8" L x 2-9/16" W x 2-3/4" H
A must have for every workshop
Name:	UK speed control.jpg
post #5 of 10 (permalink) Old 05-24-2012, 08:42 AM
First Name: Art
I'm not sure if a conversion plug would work like it does on other electronics but if it would you can get a speed controller at Harbor Freight for very little money.
mgmine is offline
post #6 of 10 (permalink) Old 05-24-2012, 10:06 AM
Hi Art
The HF or the MLCS ones will not work on the 220 volt setup.
post #7 of 10 (permalink) Old 05-25-2012, 06:31 PM Thread Starter
Default Thanks to all
Thanks everyone.
And thanks to bobj3. That is what I am after. The guy who sells them is away and wont be back until early June so I will get one then.
Alex
post #8 of 10 (permalink) Old 05-25-2012, 07:43 PM
You're Welcome Alex
They are very hard to find you may want to buy more than one and sale the others off to pay for yours.. (hint)
Thanks everyone.
Alex
post #9 of 10 (permalink) Old 05-26-2012, 04:44 AM
First Name: Geoff
The Super PID speed control is very good and maintains a constant speed regardless of router load. It's not cheap and installation does require some wiring at mains voltage but does work very well.
240V as it's made in Australia.
geoff_s is offline
post #10 of 10 (permalink) Old 06-04-2012, 12:36 AM
First Name: david
Default rheostat
just buy a rheostat light switch that is 20Amp
david cooksey is offline
Milwaukee 5625-20 15 Amp 3-1/2-Horsepower Fixed Base Variable Speed Router Review woodrouterreviewsguy Tool Reviews 1 02-23-2012 11:35 PM
Re-purposing Variable Speed Control paduke Table-mounted Routing 4 12-11-2011 07:20 PM
PC 5182 Need help making variable speed work lorencharter General Routing 4 11-11-2011 10:05 AM
By-passing RE600 Router variable speed control Esteban General Routing 0 08-23-2011 06:29 PM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 05:10 PM
