Does MCLS Powerlift only work with the plate that it is pre-mounted to? - Router Forums
post #1 of 2 (permalink) Old 06-23-2012, 05:36 PM Thread Starter
First Name: Upton
Default Does MCLS Powerlift only work with the plate that it is pre-mounted to?
Would like to buy an MCLS Powerlift, but site says it is "pre-mounted" to a 1/4" thick aluminum router table insert (9-1/32" x 12-1/16"). I would like to use it with my Bench Dog ProMax RT that has a hole that measures 8-1/4" x 11".
It the "pre-mounted" MCLS Powerlift permanently attached to the router table insert, or can it be "dismounted" and attached to the smaller router plate?
Upton O'Goode is offline
post #2 of 2 (permalink) Old 06-25-2012, 02:18 AM
allbarknobite's Avatar
First Name: Mark
Default Powerlift installation
Hi Upton.
I have been using a Powerlift for a good year, and it does work.
As for the router plate insert, it is an integral part of the Powerlift, and should not be removed. You will need to use a router table with the insert size of 9x12. You may have to use a template to rout out a smaller table size, or make your own table using the MLCS template.
Hope that helps with your decision, and have fun.
Mark
ps
Check out my posts on this forum for a xy or an xyz router table.
allbarknobite is offline
Marvel 40 Router Plate cbsjoez1935 General Routing 2 04-06-2009 05:23 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
router table top delroy33 General Routing 18 07-30-2006 04:53 AM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
