sliding cheeks - Router Forums
post #1 of 9 (permalink) Old 07-01-2012, 10:02 AM Thread Starter
burlwood's Avatar
First Name: Ron
Default sliding cheeks
I am building new fence and wanted to know the benefit of siding cheeks
burlwood is offline
post #2 of 9 (permalink) Old 07-01-2012, 10:55 AM
First Name: Don
These allow you to get support as close to the cutter as possible, which gives you more control and less tear-out.
friendly1too is offline
post #3 of 9 (permalink) Old 07-01-2012, 12:04 PM
Phil P's Avatar
First Name: Phil
Hi Ron
An alternative (or better, an addition) is to use a sacrificial fence - this is a piece of 6mm MDF or plywood whiich is fixed to the face of the fence. To use it the fence is drawn forwards to clear the cutter, the sacrificial fence attached and the fence pushed back with the router running so that it plunges through the sacrificial fence to form a "zero clearance" fence. Once cut the router is switched off and the fence fixed in position before taking the cuts. Standard practice on industrial (spindle) moulders
Regards
Phil
Phil P is offline
post #4 of 9 (permalink) Old 07-01-2012, 05:58 PM
Thumbs up
Welcome to the forum, Ron.
The only benefit I can see is to be able to adjust the width of the opening for different cutters.
I like Phil's suggestion.
Sydney, Australia
jw2170 is offline
post #5 of 9 (permalink) Old 07-02-2012, 06:23 AM
chessnut2's Avatar
Phil.....sounds interesting. Do you by any chance have a photo of this setup? I'm not quite understanding what is meant by pushing the fence back. Ji
chessnut2 is online now
post #6 of 9 (permalink) Old 07-02-2012, 07:02 AM
First Name: Kerry
This string is interesting and I'll watch for more detail.
Would any of you gents be able to suggest where I might find some plans or good explanation and maybe even some photos of a table fence?
Just finishing off a home built table and now thinking and looking for some guidance with a fence for it. Thanks gents.....
Kerry
Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
-Walter Blodget
Larkan is offline
post #7 of 9 (permalink) Old 07-02-2012, 07:29 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Interestingly enough, INCRA suggest you only use the right hand side of the fence for the zero clearance and leave the left as is. I've always cut out various shaped templates from MDF to wedge in between my fence gap to make the zero clearance fence but now I'm going to try the right-only approach.
cagenuts is offline
post #8 of 9 (permalink) Old 07-03-2012, 08:09 AM
First Name: Mal
Makes sense, close support would be useful as the bit leaves the work to prevent chipout. On the out feed side, you wouldn't want a gap wide enough for the work to get off line enough to catch at the start of the fence, but a 1/8inch clearance from fence end to nearest point on bit would be OK, particularly with a slight chamfer at the bit end of the face.
malb is offline
post #9 of 9 (permalink) Old 07-03-2012, 11:04 AM
First Name: Keith
Default My New Router Fence V 2.0
Food for thought.
This design was a culmination of features I wanted to add on my first version and I am so glad I did... the new fence is sweet!
PorterCable690 is offline
Craftex Sliding Table Saw Attachment CX200S CanuckGal Tool Reviews 6 07-02-2012 10:19 AM
How to Make Sliding Dovetails learnexperience General Routing 3 08-11-2011 10:00 PM
kobalt sliding miter compared to craftsman sliding miter murph New Member Introductions 3 10-25-2009 05:57 PM
